Measuring Tools & Sensors Logo
Keith Tabor Posted on Oct 12, 2017
My Radio Shack indoor/outdoor thermometer sensor reads LL.L. Just replaced the batteries
Radio shack 63-1024 manual download?
Various similar Radio Shack indoor outdoor thermometers, but not yours. Probable close enough though.
https://www.google.com/search?q=Radio+shack+63-1024+manual
2answers
Radio Shack outdoor thermometer remote sensor 63-1026 reads LL.L Replacing batteries and reset didnt help. How to fix?
Try cleaning the outdoor thermometer transmitter unit by opening it up enough to spray compressed air (Ultra Duster or similar) on the temperature sensor. It fixed the hh.h error for me.
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
Did you reset the sensors after replacing the batteries? Bring the sensor inside and close to the main unit. Replace batteries on both units. Use a thumb tack and stick it into small reset hole near battery compartment to reset both units. If that doesn't work, your sensor needs more troubleshooting or needs to be replaced.
Why does my thermometer say LLL?
Sensor has gone bad if new batteries, taking it inside (if freezing cold out) and a reset didn't fix it.
LL.L means temperature is below range, i.e. no signal from sensor.
Outdoor temp reads HH.H. How do I get it to display the temp again?
Mine reads HH.H on outdoor after a hailstorm. The wire was broken to the outdoor sensor.
4helpful
Outside temperature not showing on ll bean model # 9021u-it
Try removing the batteries from both the outdoor sensor and the indoor unit. I had the same problem and fixed it by doing this.
Digital Thermometer wont power up after new battery
This thermometer has a battery. It sounds like the battery needs to be replaced. Take it to radio shack, they will do it for u.
25helpful
7answers
GE Digital Wireless Thermometer
Wireless Digital Thermometer GE5805WS4
Instruction Manual
Buttons and Functions
Button Function
Front of unit:
Min/Max...........displays Min or Max temps recorded
CH(Channel)......changes displayed channel
(hold 3 sec to erase)
Clear................clears memory in Min/max display
Back of unit:
C/F....................Toggle between Celsius
or Fahrenheit temperature display
Scroll.................Remote Channel Scrolling ON/OFF
INSTALLING BATTERIES
IMPORTANT:Read the section SETTING UP THE THERMOMETER before installing the batteries for the first time.
1.Remove the rear cover of thermometer. Install 2 new AA batteries. Replace battery cover.
2.Loosen 4 screws on rear battery cover of the Remote Sensor and slide battery cover off.
3.Install 2 new AA batteries .
4.After batteries are installed, the remote sensor will begin transmitting and automatically register to the Thermometer
(within range) after several minutes. However, you can also press the small button in the battery compartment (labeled Tx) to register the Remote Sensor to the Thermometer immediately
5.Replace battery cover and tighten 4 battery screws. Make ure that the battery cover is fully on and tightened to assure a watertight seal.
The thermometer can monitor up to two different Remote Sensors on two separate channels. Add-on remote sensors can be purchased separately and are compatible with the GE Wireless Thermometer/Clock (model GE5805WS4) as well as this unit. When first installing, always insert batteries into the Thermometer first, then into the Remote Sensor.
The thermometer uses random security code technology-it will learn the random code of the first Remote Sensor it detects and log in as channel 1. Channel 2 will register in the same way. NOTE: Registered channels will be erased when the batteries of the Thermometer or Remote Sensor are removed. When replacing batteries for a Remote Sensor, remember to clear the corresponding channel of the Thermometer in this way:
1.Remove batteries from the remote sensor (step 2 of installing batterie)
2.Select the channel that you would like to clear by pressing the CH button on the Thermometer until this channel number is displayed.
3.Hold the CH button for 3 seconds to clear the channel
4.Follow steps 3-5
MOUNTING THE REMOTE SENSOR AND THERMOMETER
Remote Sensor is suitable for outdoor mounting (watertight) at a range up to 100 feet from the Thermometer. HOWEVER, HE UNIT SHOULD NOT BE MOUNTED IN A POSITiON WHERE IT WILL BE SUBMERSED IN WATER, OR EXPOSED TO DIRECT SUNLIGHT, OR NEAR OTHER SOURCES OF HEAT OR COLD (I won't bother typing the rest) except for:
LOW Battery icon for the sensor will show up on either the
ch 1 or ch 2 display depending on which sensor is losing battery power.
Battery life 6 months
Temp Range Therm 32 to 122 deg F
Remote Sensor -58 to 158 deg F *
*Alkaline batteries can freeze temporarily at temps below -4 deg F. In this condition, the Remote Sensor cannot accurately transmit temp info to the Thermometer. This limits the effective minimum temp fo the Remote Sensor to -4 deg F
Operational Range....>50ft(and up to 100ft)(less interferances)
RF Channel ....refresh to "---" if no signal received in 60 minutes
Top Radio Shack Measuring Tools & Sensors Experts
Ngoro
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
