Question about Locks & Locksmithing
Missing master key for Grafter electronic safe item no.GT24-150 Key number 842220. Previous occupant now deceased.
Posted by wilkins1945 on
5 Related Answers
Anonymous
SOURCE: BATTERIES FLAT CANNOT OPEN MICROMARK SAFE WITH KEY
http://www.rotteneggs.com/r3/show/se/198433.html
:D x
Posted on Jun 02, 2009
David Shaub
  • 2976 Answers
SOURCE: micromark Electronic safe
Contact the manufacturer with the model and serial numbers. They CAN supply a default passcode number.
Posted on Aug 07, 2009
Anonymous
  • 160 Answers
SOURCE: I can't reset by keypad on my cannon gun safe electronic key pad
First I would try the original numbers to see if you did change it. If the original numbers work then you need to start over. If they don't work then the new numbers you installed are there and you need to figure out what you punched in not what you meant to punch in.
Hope this Helps,
RSMITH972278
P.S. FOR FURTHER ASSISTANCE PLEASE PROVIDE MAKE AND MODEL
P.P.S. PLEASE RATE ME
Posted on Nov 24, 2009
Anonymous
SOURCE: SD102 missing the key
Hi.
Yes, you need the key to open it.
Your code is 4 numbers (one or two digits each).
First turn the knob several times counter clockwise To "reset for starting)
Turn the knob clockwise. Stop when you hit the first number the fourth time. Then counterclockwise, and stop when hitting the second number the third time. Counterclockwise again until you hit the third number the second time. Counterclockwise, and stop when hitting the fourth number the first time.
Now you need the key. The safe opens when you turn the key clockwise. I don't know where to order a new key, but I suppose the manufacturer can help. Your key number should be engraved ON the lock. Mine has four digits lock/ key- number.
I have not been able to find the manufacturers web page...
I wish you luck!
Stein/ Norway
Posted on Feb 13, 2010
Testimonial: "thank you very much. i will look for the manufacturer:)"
Anonymous
SOURCE: I purchased a Grafter Electronic
Inside the door on the hinge side is a button press and release this and release this and you will hear two beeps.
Now input your code of between 3 and 8 numbers and confirm by pressing either A or B.
Hope this helps.
Posted on Feb 07, 2011
Ive locked myself out of my safe which is a Grafter 24/188
Take it back to the store or to a locksmiths......... or give it back to the previous owner.????
Mar 13, 2018 | Cars & Trucks
The batteries are dead in my grafter electronic digital safe and the keys went missing a few years ago. can you help?
The only option is to have the lock picked and a new one fitted if you wish to continue use of the safe
Jan 19, 2017 | Home Security
Grafter electronic digital safe
No we can't help with this, please call a local locksmith.
Jul 13, 2017 | Locks & Locksmithing
I HAVE A GRAFTER ELECTRONIC DIGITAL SAFE WITH A LOCKED DOOR, NO KEY, NO CODE AND AT THE MOMENT NO LUCK. CAN YOU PLEASE HELP. ?
If the safe isn't fixed to the wall or floor, then you can easily open the door in seconds.
Just balance the safe on it's rear edge, tilted back about 45 degrees, so the front is about 4" off the ground.
Hold the door release gently and allow the safe to fall flat, as you hear the impact, turn the release clockwise. Timing is everything and it took me 4 goes to get it right.
Jun 20, 2011 | Safe International Digital Electronic Safe...
I purchased a Grafter Electronic Digital safe from Aldi. Never used but have no instructions.- got 2 keys. Can you please give me instructions, how to use and put in my code numbers.Thank you R.Taylor
Hope this helps.
Feb 01, 2011 | Safe International Digital Electronic Safe...
Fwellshave lostkeyandforgtton code Grafter electronic safe number960352
Lost keys AND fogotten code ???? Write to the safe company, if they cant help, there is the option of a metal cut off saw, just rotate and cut always on top !
Oct 28, 2009 | Safe International Digital Electronic Safe...
Hi.
I wish you luck!
Stein/ Norway
Jul 08, 2009 | Safe International Digital Electronic Safe...
Locks & Locksmithing Logo
195 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
