Question about EliteGroup P4S5MG/GL+ Motherboard
Connection I have removed the connection from the motherboard to clean it. Unfortunately cannot locate the manuals so need assistance for reconnecting Front panel connection. Thanks
Posted by Krsna on
  • Anonymous Jan 26, 2008
    dont have manual need where power sw./reset/hd led/ wis installed on motherboard p4s5mg/gl
  • hey-u Feb 10, 2008
    need manual or diagram on pin connections for case to motherboard for p4s5mg/gl. reset sw./hhd led/power sw./power led ect..
Anonymous
  • 44 Answers
This should work: http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=57&areaid=2&LanID=0
Posted on Dec 19, 2007
6 beeps when turning on computer
Open the back cover of cpu cabinet.Then you can see motherboard reconnect RAM memory pci card or vga card if any.Make sure motherboard is not ground with cabinet cover.Then check if still same then try with another RAM memory then it should be work clean dust from all parts inside cpu also reconnect all connection to motherboard reconnect both connection to cd dvd rom and harddrive.Let me know if you need further assistance.Thanks for using FixYa.
Nov 20, 2011 | Dell Dimension 8400 PC Desktop
Beeping when turning on and monitor not working
Nov 20, 2011 | Dell OptiPlex GX280 PC Desktop
Emacine t2042 beeps once-beeps 3-beeps3-beeps once butr does not boot. What the heck does the beeping mean?
Open the cpu cabinet cover . Then reconnect RAM memory to motherboard clean dust from all parts. Reconnect processor and it's fan reconnect pci if any. Reconnect both connection to harddrive. Make sure motherboard is not ground with cabinet cover. then check. Let me know if you need further assistance. Thanks for using FixYa.
Sep 25, 2011 | E-Machines T2042 PC Desktop
The comp is experiencing booting problems
Open the back cover of cpu cabinet. Then reconnect RAM memory and both connection to harddrive . Pull cmos cell from motherboard for 10 minutes then put it back reconnect all connection to motherboard and ATX connector, make sure RAM is working fine and harddrive recognized in bios . Make sure motherboard doesnot ground with cabinet. Reconnect pci card if any. Let me know if you need further assistance. Thanks for using FixYa.
Sep 22, 2011 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
My computer randomly will not power on. It doesnt work more than it does work. It will power on but will not fully boot up, monitor screen is blank and mouse does not power on. Light on front of tower...
Open the cpu cabinet cover then clean motherboard and parts. Reconnect RAM memory.Pull cmos cell from motherboard for 10 minutes then put it back reconnect both connection to harddrive.Make sure motherboard is not ground with cabinet cover. Reconnect pci card if any. Let me know if you need further assistance. Thanks for using FixYa.
Sep 01, 2011 | Gateway DX4200-UB001A Desktop Computer
Hi i have an acer aspire desktop with just a black screen no bios cpu fan is spinning but really fast
You need to check the RAM memory. For that open back cover of cpu then on motherboard you can see RAM memory reconnect it to motherboard .Pull cmos cell from motherboard for 10 minutes reconnect all connection again inside the cpu.Make sure motherboard it not ground with cabinet cover. Then check.Reconnect PCI card or vga card if any. Let me know if you need further assistance. Thanks for using FixYa.
Jul 06, 2011 | Acer Aspire X3200 PC Desktop
THERE WAS POWER CUT SOME DAYS THEN THE RAM OF MY COMPUTER GET BURNED.I BOUGHT A NEW ONE, BUT THE COMPUTER IS STILL NOT DISPLAYING, BUT ALL COOLING-FANS ARE RUNNING.THE KEY BOARD,MOUSE AND MONITOR DONT...
For that open cpu cabinet cover.Then reconnect RAM memory.Try RAM in another slot. Pull cmos cell from motherboard for 10 minutes then put it back.Reconnect both connection to harddrive. Reconnect Pci card if any.Make sure motherboard is not ground with cabinet. Reconnect All connection to motherboard. Let me know if you need further assistance. Thanks for using FixYa.
Apr 05, 2011 | Computers & Internet
Computer does not switch on and has a long beeping sound what might be the problem?
Long beep means you need to reconnect RAM memory and processor and it's fan Also reconnect PCI card if any. make sure RAM memory is working fine. Open back cover of cpu reconnect RAM memory Clean dust from all parts. Also reconnect both connection to harddrive. Make sure motherboard is not ground with cabinet cover. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Nov 15, 2010 | Dell OptiPlex GX280 PC Desktop
Acer 4520 AMD Motherboard will be not boot.when i press Alt+F2key with Power on key system start and Bios screen on but with in 5sec its Hang. please solve my problem.
Reattach the ram memory .Reconnect both connection to harddrive.
Reconnect processor and it's fan.
Pull cmos cell from motherboard for 10 minutes so all settings defaults.
Remove pci or vga card if any.
REmove dust from all parts.
Then check.
Mar 13, 2010 | Computers & Internet
Connection
pixel.gif pixel.gif =1024) && (screen.height>=768)) { document.write( 'pixel.gifSearch
btips.gif'); } //--> dot.gif
dot.gif manual, information? Part number
Manual
Warranty information
Refund information
Rebate information
Serial numbers / manufacturer numbers
Billing information
Missing or lost CD, disk, or install file
Upgrade information
Part Number There are literally millions if not billions of different part numbers used by companies today. Because of the vast quantity of part numbers and the frequency of those numbers getting changed or referenced to other numbers, Computer Hope is unable to offer its customers with third-party part numbers.
If you are looking for a part number we recommend that you contact the computer company or the company responsible for supporting your product. You can find a listing of companies and their contact information on our company listing.
If the company responsible for your product is no longer in business we recommend the below.
  • If you do not have any numbers, but have the product or part you wish to replace, ensure that no numbers are listed on that part. If a number or name of company is listed on the product see the next section. However, if no number can be located we recommend you take the product to a local service center, repair shop, or the place of purchase for additional assistance.
  • If you are able to locate a number, attempt to search the Internet with a large search engine for that number. If you are unable to locate that number we recommend you take the product to a local service center, repair shop, or the place of purchase for additional assistance.
  • If you are only able to locate the name of the company who made the product, attempt to contact that company directly to see if they can provide you with a replacement. See our company listing for contact information.
Also see: Part Number (PN) Computer Hope dictionary definition.
Manual suggest you visit the manufacturer of your product web page.
Also see: Manual Computer Hope dictionary definition
Serial Numbers Unfortunately, with the billions of different serial numbers and manufacturer numbers, contact the manufacturer of the product or look for information about the product on Computer Hope by searching by the manufacturer or type of device name. For example, instead of searching for "Serial Number 12345" it may be easier to search for "Maxtor hard drive".
If you are looking for a serial number for a particular software program you will need to contact the software developer or producer of the software program; Computer Hope will not provide any type of serial numbers or other registration numbers to any users. See our underground section for additional information to why Computer Hope does not provide this information.
Finally, a serial number for a hardware device such as a computer or printer can almost always be found on the bottom or back of the device. If you're trying to find the serial number for one of these devices try physically examining the device. If you're still having issues locating it the contact the manufacturer .
Missing or lost CD, disk, or install file If you've lost one or more of your installation CD's or diskettes you must contact the developer of that program to obtain a new copy. Computer Hope cannot send anyone copies of the disks or downloadable files over the Internet of the program regardless if you have purchased the program.
Dec 06, 2007 | Computers & Internet
EliteGroup P4S5MG/GL+ Motherboard Logo
238 people viewed this question
Top EliteGroup Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
