Question about Panasonic Cameras
I had misplaced my Panasonic DMC-TZ4 camera, I recharged the battery and I can view my previous picture but, cannot see new objects on the screen in order to take a new picturew
Posted by CHARLES W JACKSON on
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: Panasonic DMC-LC1 Camera help, Black Screen
Clean everithing around the battery conections, try another battery too, check the polarity (basiks).
Try to use with the computer in webcam mode.
But dont try too hard if the common sence not workig, use the warranty!!!
Posted on Nov 11, 2007
mm46
SOURCE: Panasonic Lumix DMC-LC1 Digital Camera Problem
Contact Panasonic - there is a widespread problem with CCDs in the last 3 or 4 years - keep pressing them for free repair as is your due with faulty goods, even outside the warranty period.
See the following link:-
Widespread CCD problems in consumer imaging productsCCD Sensor Problems in Consumer Imaging Products .... Given that the Leica DIGILUX 2 is a variant of Panasonic's Lumix DMC-LC1 design, it isn't surprising ...
www.imaging-resource.com/badccds.html - 51k - Cached - Similar pages
Posted on Feb 25, 2008
SOURCE: Problems with my Panasonic Lumix Digital camera
let me explain to you guys, these cameras are slim line cameras and if dropped or mishandled it is going to give problems. you cant blame the camera if you are not handling it corectly.
Posted on Jul 09, 2008
Parshiv Luthra
  • 395 Answers
SOURCE: pink screen and blurred pictures
The problem is with the CCd ..... Kindly get it replaced ...
Posted on Nov 14, 2008
Anonymous
  • 3006 Answers
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
Posted on Nov 28, 2009
I have lost the manual on the use of my Lumix Panasonic model no DMC-TZ5
http://service.us.panasonic.com/OPERMANPDF/DMCTZ4.PDF
The filename says TZ4, but it's the manual for both the TZ4 and the TZ5.
Jun 06, 2011 | Panasonic DMC-TZ5 Digital Camera
Hello I have a panasonic DMC-TZ4 digital
You can download and print your camera manual, at no cost, here:
http://www.brynmawr.edu/llc/documents/DMCTZ4.pdf
Apr 22, 2011 | Panasonic DMC-TZ4 Digital Camera
I have a Panasonic DMC-TZ4 camera. I am on vacation and my settings got changed. I do not have the manuel with me. My flash won't work for indoor pictures and I do not know how to change the settings. Help
One of the buttons on the back has a lightning bolt icon. In picture taking mode, press the button and watch the screen....it will cycle through auto flash, red-eye flash, flash off, etc.
Oct 27, 2010 | Panasonic DMC-TZ4 Digital Camera
Lumix DMC-tz4 Camera will not turn on . Battery appears to be charged, get just over 4 volts on multimeter. Any suggestions
Hello :
I recommend you to put a new battery , because it seems that your battery life is ended . When battery life is ended it can't be recharged any more . Maybe it shows some volts but there will not be any current flow in it .
Check the cords and the charger also please , just to be sure that they are fine .
good luck .
rate please !
Mar 19, 2010 | Panasonic Cameras
Nov 28, 2009 | Panasonic Lumix DMC-FZ18K Digital Camera
My panasonic dmc-lz6 wont turn on
Replace batteries with new ones or recharge them if they are rechargeable.
If this operation won't help, then check the objective, because it could be jamed or blocked - in this case the LCD shows a message:"You should turn off and on the camera!" Something like that.
Nov 21, 2009 | Panasonic Lumix DMC-LZ6 Digital Camera
Lost manuel
Hi! You can download a manual at the following link for your camera. It's in a PDF format, so you have to have Adobe Acrobat Reader installed on your computer. (Free download at www.adobe.com ) Then go to the link below and follow directions to view or download the manual. Hope this helps! Hal
http://www.dphotojournal.com/panasonic-lumix-dmc-tz4-review-samples/
Jun 08, 2009 | Cameras
Dim pictures from panasonic tz4
TZ stands for Travel Zoom. This means you get a small camera with a large zoom mainly made for outdoor good lighting conditions. But, there are custom setting that may allow you to correct for lighting. Try the Vivid color saturated setting on this camera.
It will not do as well as other cameras in lower light or moving objects.
Dec 17, 2008 | Panasonic DMC-TZ4 Digital Camera
Nov 11, 2007 | Panasonic Lumix DMC-LC1 Digital Camera
Cameras Logo
Top Panasonic Cameras Experts
ENFORCER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
