Question about Locks & Locksmithing
I just switched from lock box to lockbox pro. It requires to change my lockbox code ! I've tried 50+ 4 digit entries but it constantly says incorrect code, what am I doing wrong.
I can't get on Facebook or google because my codes are locked on lockbox!
Posted by Gayle Mullins on
5 Related Answers
Anonymous
  • 97 Answers
SOURCE: Google G1 locked out
T-mobile is the only wireless provider that will even work with this phone....so kinda a no brainer....;)
if you had too many incorrect pattern attemps, the handset will automatically lock you out of your handset....if thats the case, the only thing left to do, is either go to the link i have below and trying to restore the forgotten username and/or password....just answer the questions the webside asks for and you can log in again....
http://mail.google.com/support/bin/answer.py?answer=46346&fpUrl=https%3A%2F%2Fwww.google.com%2Faccounts%2FForgotPasswd%3FfpOnly%3D1%26continue%3Dhttp%253A%252F%252Fmail.google.com%252Fmail%252F%253Fhl%253Den%2526tab%253Dwm%2526ui%253Dhtml%2526zy%253Dl%26hl%3Den%26service%3Dmail%26ltmpl%3Ddefault&fuUrl=https%3A%2F%2Fwww.google.com%2Faccounts%2FForgotPasswd%3FfuOnly%3D1%26continue%3Dhttp%253A%252F%252Fmail.google.com%252Fmail%252F%253Fhl%253Den%2526tab%253Dwm%2526ui%253Dhtml%2526zy%253Dl%26hl%3Den%26service%3Dmail%26ltmpl%3Ddefault&hl=en
if that fails you will have to reset your handset and create a new login with your phone.
the handset will need to be powered off, then press and hold the house and the red buttons at the same time until you see a triangle with a yellow "!" inside....when you see this screen release those keys and slide open the keypad and press the "ALT" and "W" keys at the same time. the handset will turn off and power on again and walk you through the setup. here you can either attempt to sign in again with the underscore or you can create a new account.
*******careful, any new numbers you added since you had the g1 will be lost if you cannot log in again with the same username and password******
good luck! :)
Posted on Jan 21, 2009
Anonymous
SOURCE: ive locked my g1, too many wrong attempts on
1. Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Posted on May 22, 2009
Anonymous
SOURCE: Bought used phone, Need phone lock code to format memory card
It is either the last 4 digits of your number or a personalized code.
Posted on Dec 01, 2009
Anonymous
SOURCE: Schlage FE365v keyless entry lock.. Lost manual. Forgot 6 digit programming code. Need instructions to restore and set all new codes.
look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
Posted on Aug 08, 2010
Anonymous
  • 74 Answers
SOURCE: Kwik Set keyless entry lock. We
With the door open so u dont get locked out,did u remove the batterys and try to re-set your door code ?
Posted on Dec 18, 2010
Tip
How to chanmge codes on most digital safes
To change the code on most digital safes. <br />you need to access the red button usually found inside the safe by the battery area. <br />Press the red button until you see two flashes. then enter your new code.<br /><br />PLEASE try the code BEFORE you close safe!! <br /><br />Thanks
on Apr 29, 2011 | Safe International Digital Electronic Safe...
My sister locked herself out of her Justice digital safe and it is on voice mode, every time we try to reset the passcode it does not work. Does this mean that the safe is broken?
The safe would need to be open to change the passcode. Also there may be a time delay after several incorrect attempts to open. I am not at all familiar with this brand.
Jul 21, 2014 | Safe International Digital Electronic Safe...
We don't remember the code please help with the axample
You must be having the manual override keys. Just open the safe with those keys and reset the passcode.
Jul 14, 2014 | Safe International Digital Electronic Safe...
How to reset the entry code to homcom 12"x14"x10"
Most of these Chinese safes have a reset button inside the safe. Open the safe, press reset and enter your new combination. Then check it before closing and locking the safe.
Jul 12, 2014 | Safe International Digital Electronic Safe...
I NEED TO RESET THE MASTER CODE ON THE GORDON DIGITAL SAFE BUT I DO NOT KNOW THE OLD MASTER CODE
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Apr 14, 2010 | Safe International Digital Electronic Safe...
Change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
Nov 22, 2009 | Safe International Digital Electronic Safe...
I want to reset the entry combination
Try and use default code 159a then try and reset if not go to harborfreight.com put in safe it has instructions on how to change all these are the same even if name is different
Oct 02, 2009 | Safe International Digital Electronic Safe...
Locks & Locksmithing Logo
151 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
