Question about DeLonghi EO1260 1400 Watts Toaster Oven with Convection Cooking
DGI EO1260 KNOB BROKE
ONE OF THE KNOBS BROKE. I BOUGHT AT PC RICHARDS BUT WANT TO HAVE A NEW KNOB SENT TO ME
Posted by bethgrossman on
  • delonghiknob Mar 25, 2008
    The middle knob, the most used one that controls on/off and the timer has broken. At the moment I am using the bottom knob (broil, toast, bake). I'm not having much luck finding a replacement knob.
  • Anonymous Apr 08, 2008
    Exactly the same problem. Just happened the other day. Today we were able to toast but cannot use just over or broil.
    I have the name of a company I am going to call that handles lots of parts including out of production but can't find the number at present.
    Pliers work also!!
    maria
Lisa Janssen
    Problem Solver:
  • 6 Answers
Go to PartStore.com. Item # 5318135200. $.99 ea. S&H $8.95.
Posted on Nov 11, 2011
  • Joyce Schwab Nov 07, 2013
    What about the little spring inside? I order that part but it did not come in the knob. I did not know I had to save it.
Anonymous
I broke the plastic dail for the toaster/toast/bake/ dail. Where can i get a new plastic dial?
Contact Euro-Pro by phone at (800) 798-7398. b The replacement knobs will cost you about $10 (3 knobs and shipping and handling) Call-don't email as I got the wrong information when I emailed. You are better off speaking with a person, even if they are in India.
Oct 13, 2009 | Euro-Pro EP278 Bravetti Platinum 1500...
Oster 6232 toaster oven.
trying to find a solution for a broken knob, i discovered that there aren't many decent options. so i took it upon myself to find one. my father actually recommended that i post the solution, seeing that there were so many with broken knobs. now this works on the timer knob on an oster 6232 toaster oven. it may work on the other knobs and possibly other models, but i cannot confirm that. the plastic stem of the knob that slips over the medal stem of the timer had broken. i crazy glued it back together and knew that there was no way in hell it would hold up with just glue. sorry for the lack of pics on this part. with the broken piece glued back in place, i went to home depot to find something/ anything that would securely slip over the stem of the knob. i tried all sorts of tubing. copper, pvc, steel and found nothing. in the plumbing isle with all the brass fittings and compression fittings, i found an "ander-lign compression nut" 5/8" OD w/ insert. part # A-304 961-P. 634052c.jpg
all you need is the brass flanged insert. if you can find it without the nut and compression ring, then more power to you. after buying this, slip the piece over the knob stem flanged end first. i used 5 minute opoxy to ensure it would stay in place. 7c9f2a3.jpg
i then used a cone shaped diamond bit in my dremel tool to notch out the two sides of the knob. 6be2e7e.jpg
just cut the brass down enough to match the notches in the stem of the knob. 0cdfdf7.jpg
and there you have it. sorry for the 2 blurry pics. hope this can help some of you.
Sep 15, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Knobs are broken. Need new ones
here is what i just did with mine that i bought used, i put some jb weld into the socket of the knob and i am waiting to see if it will be a success! it is an idea though. have to give me credit for trying. mine was the timer knob. jerry
Aug 23, 2009 | Oster 6071 Toaster Oven with Convection...
My delonghi toaster oven knobs broke! as
Hi, you can purchase them on amazon. Here: Amazon com delonghi knobs. I think this was helpful, Have a nice day
Jun 12, 2009 | DeLonghi EO1260 1400 Watts Toaster Oven...
Knob to my toaster oven broken
Thanks for allowing me to help you with this problem. It took a while but I was able to find the information you need. Just click on this link:
www.euro-pro.com/europro/productdetail.aspx?pid=8093C938-4393-47B8-A9B5-9D606596B9CE(Euro-Pro+Base+Catalog)
Figure out what you need and place your order. If my information was helpful, please give me a good rating. Thanks for using FixYa!
Jan 28, 2009 | Euro-Pro EuroPro 6Slice Toaster Oven with...
OSTER TOASTER OVEN --- TIMER TWIST KNOB BROKE
you can get on amazon for sure. take a look here Thanksgiving essentials from the Oster brand. p.s. take a look on seller reviews. I hope this was helpful. cheers
Jan 19, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
I bought a kenmore toaster oven. There were no instructions.
This controls the heating elements in the oven Briol// Bake// and Toast
Dec 16, 2008 | Toaster Ovens
DeLonghi EO1260 1400 Watts Toaster Oven with Convection Cooking Logo
467 people viewed this question
Top DeLonghi Toaster Ovens Experts
Marvin
Marvin
ray gallant
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
