Question about Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag
Hi, I have a S646 SE my joystick started flashing yesterday every 5 sec it flashes the w/c icon 3 times and the battery indicator flashes 3 red 4 orange & 1 green. What does this mean?
Posted by steve merritt on
Scooter Doctor
    Master:
  • Electric Mob... Master
  • 401 Answers
Most of the time a flash code of 8 means the controller has a fault. but sometimes there maybe a damaged cable connecting the joystick to the controller.Sorry for the bad news.
Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Posted on Oct 10, 2017
5 Related Answers
Pyrhyc
Ryan Rogers
  • 2028 Answers
SOURCE: flashing battery icon
Battery is shot, time for a replacement. Keep in mind that a Dell battery can aquire a dead short, this won't hurt the system, but it can keep the machine from starting up. If you find that your machine won't start up try pulling the battery.
Posted on Jun 10, 2008
Anonymous
  • 203 Answers
SOURCE: Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Posted on Sep 14, 2008
Anonymous
  • 741 Answers
SOURCE: battery light flashes red 4 times
Check your users manual. Normally if it is blinking it is powering up, but may be different depending on model.
Posted on Jan 01, 2009
Anonymous
  • 326 Answers
SOURCE: Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Posted on Jan 31, 2009
Anonymous
  • 101 Answers
SOURCE: battery indicator light flashes 4 orange than 1
Try Charging your battery overnight if it does not recover time to change the battery.
Posted on Mar 02, 2009
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
Mar 28, 2016 | Pride Mobility Used Power Chairs Jazzy...
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
My question is related to an Invacare-Nutron R51.Production date 1-7-03,joystick[MKIV R11] flashes red 1 time, than green 5 times repeatedly? Can you please tell me what this means.?
Ranch well the red flash indicates a low battery and the 5 flashes indicate a bad left brake. Now try charging the batteries until you get a green light on your charger then turn on the chair it shouldn't flash the red if the batteries are accepting the charge. If your batteries are 2-3 years old it could be time to change them. If Medicare paid for your chair then they will pay most of the repair costs. You can contact your provider for help or a service company like Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733. If Medicare did buy the chair then you are eligible for a new chair every 5 years and yours is almost 8 years old. Contact a local provider that you trust to check into getting you a new chair. Hope this helps you
Sep 29, 2010 | Invacare Pronto M51 Power Wheelchair
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
Jan 31, 2009 | Panasonic PT-44LCX65 Television
Battery light flashes red 4 times
Jan 01, 2009 | Dell Inspiron E1505 Notebook
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
Dec 02, 2008 | Dell Latitude D505 Notebook
Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag Logo
57 people viewed this question
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
