Question about Kelvinator Refrigerators
My Vintage Kelvinator refrigerator has handles that are falling apart and I need replacement door and draw handles. Where can i find replacement parts? its a 1941 Kelvinator C-1-R fridge
Posted by Michael Morris on
David Emmel
    Sergeant:
  • 295 Answers
5 Related Answers
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Posted on Feb 12, 2008
Anonymous
  • 65 Answers
SOURCE: Freezer door handle loose
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
Posted on May 26, 2009
djmerchant
  • 3 Answers
SOURCE: driver side inside door handle replacement
I have the same problem and I can offer a temporary solution until you can get the handle replaced.
Remove the plastic handle guard. (It's simple- just open the screw cover and remove the screw.)
Push in on the rear of the triangular lock with your thumb and the door SHOULD open. At least it works for me.
Posted on Oct 21, 2009
Anonymous
SOURCE: kelvinator Opal CS 390 F door has dropped down on handle side.
My sister has the same fridge model. We've removed the door and the bottom bracket supporting the hinge had collapsed up inside the door. We're going to cut out a piece of steel (3-4mm thick) and glue it along the bottom of the door in order for the door hinge to insert into something solid. Looks like it's a weak point in the door construction. Pity Kelvinator wouldn't acknowledge the problem and come up with a solution (other than replacing the door at $340 - which is what we were quoted).
Posted on Nov 08, 2009
Anonymous
  • 269 Answers
SOURCE: How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Posted on Jun 08, 2010
How do i replace the freezer door handle on samsung rf263
Usually you have to remove all the screws around the inside door panel...which are behind the door gasket, and throug the inside door panel...
May 25, 2014 | Samsung RF265AA Bottom Freezer French Door...
Need to find a door handle for a Philco refridgator 1950 Model No. F-1218 It broke and really need to know where to find one or how to get one made any ideas from anyone
There are a few places that specilize in restoring vintage places i have included a google search link for some of them and perhaps they can help ya find that handle
http://www.antiqueappliances.com/parts.htm
http://store.antiqueappliances.com/Refrigerator-Parts_c_1.html
http://www.denisbyrne.com/fridge.html
http://www.davesrepair.com/vintageparts.htm
Many others could be found by searching either vintage or antique appliance parts
Good luck i hope this helps ya,
GENE
Sep 18, 2011 | Refrigerators
The freezer handle is loose on one side. How can
Check to see if your freezer handle has an inlay in the handle or trim that pops off to get at a screw that holds the handle onto the door. If you don't have this then you may have a handle that literally slides up and off. You then tighten the mounting screws or replace the handle if that is what is making it loose. We no longer can tear apart the doors on refrigerators to get at components inside, because the factory puts these together and shoots liquid insulation into the cavity, and this insulation expands and hardens making it impossible to tear doors apart anymore. This is why most handles now are front repairable. Good Luck. Appliance Specialists
Dec 11, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kelvinator Opal CS 390 F door has dropped down on handle side.
Apr 26, 2009 | Refrigerators
Kelvinator model N641n
I have a kelvinator refrigerator, top-mount type model # SKNT 16E.
220V, 1-phase, Defrost amps 1.9, Watts 575,
Gross/Liters 453/396
I have replaced new door gasket.
Freezer gasket is in very condition.
Compressor drawing 3.15amps.
  1. Question is Compressor is working 8 minutes and remains off for 3 minutes.This cycle is happening from some days.Thermostat and timers seem to be ok. Do i need to change Overload cut-out at the compressor or not....please suggest.
masood
[email protected]
Feb 18, 2009 | Refrigerators
Shelf locators broken of the back the freezer on kelvinator impression series 500l
hi When a refrigerator gasket (usually a rubber seal around the door) becomes hard or cracked, its seal is broken, and the unit's efficiency drops sharply. Test the door gasket for leaks by placing a dollar bill between the gasket and the door jamb and closing the door. Pull the bill out. If it offers some resistance, chances are the gasket fits properly. If the bill comes right out, or falls out, the gasket is faulty and should be replaced. Test the gasket at several locations around the door. Before you replace the gasket, check the door hinges for leakage.
Oct 17, 2008 | Refrigerators
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Handle on oven door falling
Murray...after a DJ here in NY from the '60's!
First, why is the handle falling off? Is it loose or damaged? Most of these handles are only plastic with holes tapped in. If the holes are damaged and you can't fix them, you will have to replace. Most handles are through bolted in the door. You should be able to access those screws from the inside of the door. If not....
How do take a door apart: First locate any screws in the bottom of the door. Remove them. Open the door and remove screws from the sides and inside of door. Get help supporting the outside of the door and note that it will snap shut when you remove any weight from the door. Caution, most door glass is not well clipped in...it may come loose!!!! You may want to take pictures of the inside of the door once you open it. Once the door is apart, locate any fasteners holding the handle and attempt to tighten them. If not successful, you'll need that new handle. Get an extra set of hands to help with removal and reinstallation of that door skin. You'll need 'em!
Nov 29, 2007 | KitchenAid KESC307 Electric Kitchen Range
Refrigerators Logo
251 people viewed this question
Top Kelvinator Refrigerators Experts
Jimmy
Marvin
Marvin
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
