Question about Hitachi Televison & Video
SOURCE: Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Posted on Aug 06, 2006
SOURCE: Thin white horizontal line center of screen!
The set should have a vertical output IC,You need to change it ,maybe you can check the B+ going to it because it might have opened the safety resistor if the IC went bad.You can check for broken board too unless the set is never move from one place.Be carefull when checking voltages ,there is still high voltage,not much but can num your whole hand.
Posted on Oct 18, 2006
SOURCE: 50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Posted on Mar 10, 2008
SOURCE: Kyocera FS2000 thin black vertical line on RHS of paper??
first try cleaning the charge roller on the drum unit or check the hot roller on the fuser
Posted on Dec 31, 2008
SOURCE: Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Posted on Jun 27, 2009
