SOURCE: Printer Problem
error occurred
1. Press CANCEL JOB to clear the print job from
the printer memory.
2. Turn the printer off, and then turn the printer
on.
3. Try printing a job from a different software application. If
the job prints, go back to the first application and try printing
a different file. (If the message only appears with a certain software
application or print job, contact the software vendor for assistance.)
4. If the message persists with different software applications and
print jobs, disconnect all cables to the printer that connect it to
the network or printer.
5. Turn the printer off.
6. Remove all memory
DIMMs or third-party DIMMs from the printer. (Do not remove the firmware
DIMM in the lowest DIMM slot.)
7. Remove all EIO devices from the
printer.
8. Turn the printer on.
9. If the error no longer exists,
install each DIMM and EIO device one at a time, making sure to turn
the printer off and back on as you install each device.
10. Replace
a DIMM or EIO device if you determine that it causes the error.
11.
Remember to reconnect all cables that connect the printer to the network
or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter.
SOURCE: Error code: 49.2F9D
ok, go to the link to fix your problem--
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
SOURCE: HP Laser Jet 4 Plus error code 52
A 52 error is a Scanner failure. Do you hear a "whirring" sound when you get the error?
That's the sound of the scanner motor running amuck.
You're probably going to have to replace the Laser/Scanner assembly or the DC Controller which controls the Laser/scanner motor.
SOURCE: HP 4200 Laser Jet Printer Error Code 82.0180
The error message "83.0180" shows that an EIO error has occured.
Perform the following workaround and see whether the issue still persist.
1. Ensure that the printer is connected directly to the wall outlet.
2. Turn off the printer and then power on and see whether the issue persist.
3. Reseat the Jetdirect card and see whether the issue still persist.
4. Reseat the jetdirect card on a different slot and see whether the issue still persist.
5. Remove all the accessories from the printer and then power on the printer. See whether the issue still persist. If the issue does not persist, add on the accessories onee by one.
6. Power on the printer and check whether the issue persist, each time an accessories are added.
7. Swap the Jet direct card with a known good jet direct card and see whether the issue still persist.
8. Perform a cold reset and see whether the issue still persist.
To do a Cold Reset:
1. Remove all cables.
2. Press & hold the Test button while applying power & continue to hold it for 10 seconds, then release it for 10 seconds, then unplug it again.
3. Connect all cables & power it back up.
4. Wait 2 minutes for discovery & DHCP. If desired, change the DHCP & address settings.
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
