Question about Food Processors
I have a tedelex autoflow food processor - Model No. FA1. It has never ever been used and I dont know how to use it - do you perhaps have an instruction book
Posted by Natalie on
5 Related Answers
Anonymous
SOURCE: It won't start
The power lights go on put the machine does not run.
Posted on Dec 20, 2007
Anonymous
  • 7 Answers
SOURCE: instruction manuel for black & decker food processor FP1445
The manual can be found here
http://www.blackanddeckerappliances.com/dyn/prod/user-guide/70/FP1435%20FP1445.pdf
Posted on Dec 20, 2008
Anonymous
SOURCE: Black and Decker Shortcut Food Processor
I just bougth this processor on weekend. Have you found a book yet. If not I can email it over to you in pdf format. Let me know. Email me at [email protected] and put in subject line, food processor. thanks
Sheila
Posted on Feb 16, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Posted on Mar 17, 2009
Anonymous
SOURCE: Need Instruction Manual for a Hamilton Beach Emmie Food Processor
Looking for a food bowl for a Hamilton Beach Emmie. food processor model 544.
Posted on Jan 12, 2010
Does anyone have a manual for a Goldair FP570 Food Processor, please?
I didn't find that model.
I did find a different model that might be of use, or perhaps you could contact the manufacturer.
http://www.goldair.co.nz/media/38274/FFP410%20Food%20Processor%20IB%20v2.pdf
May 12, 2018 | Food Processors
I need manuel for how to use Bravetti Platinum Pro Processor
We dont know exactly your model; could try this: BP101H2_REV_01505C-Reader.pdf
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 30, 2011 | Bravetti Platinum Pro Quad-Blade Food...
REPLACEMENT BLADE NEEDED FOR MORPHY RICHARDS 48504
My food processor has broken, so have lots of spares for 48504 - inc 2x blades. I can post to you?
Feb 21, 2009 | Food Processors
How to attach grating/shredding blades to GE Food Centre FP22
When you remove the regular chopper blade, it should fit on top of the stem. The chopper blade must be removed to use the slicer / shredder attachments.
Jan 05, 2009 | GE Food Processor
Model kp80b
You can see all of the blades and their function in the user manual.
The Bravetti KP80B food processor user manual can be read and saved from this website
http://www.euro-pro.com/europro/manuals/KP80B.pdf
If it's not there let me know and I will send it to you.
Rj
Sep 12, 2008 | Bravetti Quad Blade Food Processor
Food Processors Logo
322 people viewed this question
Top Food Processors Experts
Moderator Canada
Moderator Canada
ray gallant
Tom Chichester
Are you a Food Processor Expert? Answer questions, earn points and help others
