SOURCE: My Polaroid TV model not listed, it's TLX-04240B
I got the 42" Polaroid HDTV from Walmart (on Black Friday) and was able to link it to my Tivo remote using the Mitsubishi setting and code 0001.
1. Tivo Central
2. Settings
3. Remote Control
4. Part 1 and then Part 3
I use it to Power On/Off and Volume control.
SOURCE: polaroid tlx-04240b loses picture
I'm very appreciate to jranada's solution, my tv gets new life.
It's very simple to fix the problem to everyone.
My tv capacitor was not the problem.
I hope this will help everybody.
SOURCE: Polaroid TLX-04240B going to a black screen.
open the black plastic panel and the aluminum panel which has 3 screws each in the back of the tv.
look at bottom left corner of top board. to the right of the red led light,
there's these four white small switches. turn the bottom two switches to "on" and tv should be working.
SOURCE: I have a polaroid TLX-04240B . \r\nScreen is
Black screen canbe caused by bad T-CON board, main board, 24vdc power supply, backlight inverter board. Please my guide get more ideas on what to look for inside.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
SOURCE: I HAVE POLAROID TLX-04240B TV,HAS PICTURE STAY ON FOR AMOMENT &DI
I'm looking to purchase a broken TLX-04240B, the screen on ours is cracked. If you did not fix yours, I would be interested in purchasing it.
