Question about Icom Radio Communications
My Icom m35 is silent? How can I test if it's working properly
Posted by Paul van Noort on
Why am I able to drive my 2006 M35 then shuts off. It takes a few starts then will run & cut off again
Only the proper testing will find a problem
Have you done anything at all, yourself,any
testing-fuel pressure ,battery !
Jul 27, 2014 | Infiniti M35 Cars & Trucks
2006 infiniti m35 no sound from speakers
Yes an amp that is not working could cause this to happen. But I would check it out a little more because when you did the speaker test and all the speakers worked then that doesn't sound right. Find the amp and it could be just a loose connection that is giving you all these problems. Good Luck
Mar 12, 2014 | Car Audio & Video
Icom IC-A210 wont turn on
Need to check your input power lines for any voltage applied. And also need to ensure it is properly grounded.
http://www.icom.co.jp/world/support/download/manual/pdf/IC-A210_Inst_4.pdf
Jan 06, 2014 | Icom IC-A210 Panel Mount COMM Transceiver
Icom ic-m35, no transmitting
Contact the Icom service center. Their main web-page is www.icom.com. From there you can select your geographic area and service (commercial, marine, amateur, etc).
Aug 17, 2013 | Icom IC-M36 VHF Marine Radio
Toshiba doesn't have bios updates atleast not for this model
The m35 is discontinued for some time now and won't be getting any updates. If your laptop is not working well, experiences random freezeups and shutdowns, and you can't boot it properly take a look at this Toshiba m35 motherboard repair manual. This is by far one of the most common problems with the m35 and if this is the case with your laptop, a bios update won't help.
Feb 07, 2011 | Toshiba Satellite M35X-S1142 Notebook
Replacing M35-S359 motherboard with one from S320?
If the M35-S320 case is OK and the M35-S359 screen is OK and will fit the M35-S320 then I would swap the LCD screen lid and inverter over to the M35-S320 including the hard drive from the M35-S359.
It would be less work and with luck it might boot up, if not you might be able to do a system repair, worst case, you will need to reinstall Windows. Plus you have a spare drive from the M35-S320 which you can use as an external hard drive with an USB hard drive adapter case.
Jan 29, 2009 | Toshiba Satellite M35-S320 Notebook
Icom F21
It's a frequency error. It can be corrected, just give me some time, I need to figure something out first. It might take me a day or two.
Sep 06, 2008 | Icom IC-R5 Handheld Scanner
Radio Communications Logo
44 people viewed this question
Top Icom Radio Communications Experts
Robert McClure
Vincent G
Vincent G
Ngoro
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
