SOURCE: Insignia portable dvd NS Pdvd8 need battery
Hey redhouse2,
Because Insignia® is a brand primarily carried by Best Buy™ stores, there are two basic ways that you should be able to obtain a replacement battery: by contacting Insignia® technical support, or by ordering a replacement through Best Buy Partsearch.
You may always reach Insignia® by calling their toll-free hotline at (877)-467-4289. If you would prefer a self-service option, simply visit the www.Bestbuy.com website, and follow the link at the bottom of the page that says "Order Parts." Additionally, you may always contact a Partsearch agent by calling our toll-free hotline at 888-Best-Buy (888-237-8289), and requesting to speak with a parts specialist.
Please keep in mind that while some third-party companies may carry compatible batteries for this model, if your DVD player is still under the manufacturer's warranty (or a Best Buy Performance Service Plan) you may wish to seek the replacement part through Insignia® or Best Buy™ first to avoid any unnecessary charges.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
SOURCE: insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
1) On the remote control type "SETUP" button
2) Select "PREFERENCES" in the menu with
3) Validate it with the button "OK"
4) Enter the code : "224455"
5) With the direction keys type:
a) Left key : < (Nothing happens)
b) Down key : v (a menu appears on the screen
with all region)
6) Select the Region : 0 (all) with the direction keys
7) Validate it with the button "OK"
8) Finish the process by typing the "SETUP" button.
SOURCE: insignia ns-lcd32
You can download the manuals from the Insignia website at:
http://www.insignia-products.com/c-14-lcd-televisions.aspx
Jerry
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
SOURCE: Insignia NS-32LCD has sound but no picture -
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
