How do I change battery on Measuremeter Revolution Trumeter 5505E
Posted by Ron Chalmers on
  • Anonymous Oct 21, 2020
    posted to wrong forum computers, wow.
    it is a meter.
    OP the manual is clear so read the manual on your non PC METER.
    RTM is winner.
John Sheridan
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
5505E MEASUREMETER BATTERY CHANGE (3V CR-2032)
REMOVE WHEEL AND SHAFT BY GENTLY PULLING AXLE OUT OF UNIT.
DRILL OUT 7 PLASTIC HEADS WITH 3/16 DRILL BIT. (ABOUT 1\8 DEPTH)
SPLIT TWO SIDES OF CASE AND REMOVE HANDLE.
SLIDE OUT CLEAR PLASTIC CONTROL UNIT. PUSH DOWN ON BUTTONS AS YOU REMOVE SO AS NOT TO DAMAGE THEM.
PUSH DOWN SLIGHTLY TOWARD THE CASE ON LOCK TABS WHILE GENTLY PULLING CASE APART. START ON ONE END AND WORK YOUR WAY TO OTHER END. KEEP GASKET INTACT. OPEN CASE.
THERE IS A "Y" SHAPED RETAINER HOLDING IN THE BATTERY. WITH NEEDLE NOSE PLIERS, CAREFULLY SLIGHTLY SQUEEZE THE BOTTOM OF THE "Y" AND PULL UP GENTLY. YOU CAN NOW REMOVE THE BATTERY AND INSTALL THE NEW ONE. PUSH RETAINER DOWN TO LOCK BACK IN.
MAKE SURE GASKET IS IN PLACE AND PUT CASE BACK TOGETHER, MAKING SURE WHEEL ADAPTER IS IN PROPER PLACE. TURN ON AND TEST CONTROL UNIT AND TURN WHEEL ADAPTER TO MAKE SURE UNIT IS WORKING PROPERLY.
SLIDE CONTROL UNIT BACK IN BEING CAREFUL OF THE BUTTONS. RE-ASSEMBLE HANDLE AND PUT THE TWO SIDES OF THE CASE TOGETHER. I USED THREE PIECES OF ELECTRICAL TAPE TO HOLD CASE TOGETHER. ONE ON THE TOP BETWEEN THE TWO HOLES, ONE ON THE BOTTOM JUST ABOVE THE DISPLAY, AND ONE IN THE MIDDLE.
PUT THE PLASTIC PIECE IN THE HOLE AND LINE UP. MAKE SURE BOTH O-RINGS ARE ON THE AXLE SHAFT. GENTLY INSERT AXLE ALL THE WAY IN WHILE ROTATING IF NECESSARY.
I WAS SO HAPPY I HAD IT ALL BACK TOGETHER AND WORKING, I HADN'T TAKEN ANY PICTURES AND I DIDN'T FEEL LIKE TAKING IT ALL APART AGAIN. MIGHT ADD PICTURES LATER IF NEEDED. I HAD BEEN LOOKING FOR YEARS ON HOW TO CHANGE THE BATTERY, AND I FINALLY MADE UP MY MIND THAT I WAS GOING TO DO IT.
JMS 10-20-2020
Posted on Oct 21, 2020
I M getting a P0720 code error. I replaced both the revolution sensor and the speed sensor (the one with the gear) but am still getting the error. The battery connection is good.
Did you test electrical circuit's before replacing the sensors ? Do you know how they work , where battery voltage comes from ? May only be 5 volt ref. voltage from the transmission control module .
DTC P0720 VEHICLE SPEED SENSOR·A/T (REVOLUTION SENSOR) Revision: May 2004 2003 Sentra TERMINALS AND REFERENCE VALUE MEASURED BETWEEN EACH TERMINAL AND GROUND Diagnostic Procedure ECS005X0 1. CHECK INPUT SIGNAL (WITH CONSULT-II) With CONSULT-II 1. Start engine. 2. Select "TCM INPUT SIGNALS" in "DATA MONITOR" mode for "A/T" with CONSULT-II. 3. Read out the value of "VHCL/S SE·A/T" while driving. Check the value changes according to driving speed. OK or NG OK >> GO TO 3. NG >> GO TO 2. 2. CHECK REVOLUTION SENSOR (WITH CONSULT-II) With CONSULT-II 1. Start engine. - Check harness for short or open between TCM, ECM and revolution sensor. Refer to AT-129, "Wiring Diagram - AT - VSSA/T" . - Check harness for short or open between ignition switch and revolution sensor. OK or NG OK >> GO TO 3. NG >> Repair or replace damaged parts. TERMINAL WIRE COLOR ITEM CONDITION DATA (DC) 10 BR/R POWER SOURCE WHEN TURNING IGNITION SWITCH TO "ON" BATTERY VOLTAGE WHEN TURNING IGNITION SWITCH TO "OFF" 0V 29 W REVOLUTION SENSOR WHEN MOVING AT 20 KM/H (12 MPH). USE CONSULT-II PULSE FREQUENCY MEASURING FUNCTION 150 Hz 42 B/W THROTTLE POSITION SENSOR (GROUND) - 0V
https://www.nicoclub.com/FSM/Sentra/2003_Sentra/at.pdf
Look it up in factory service repair manual
Oct 15, 2018 | Nissan Cars & Trucks
How do I change the battery in a Trumeter measuring wheel 5505E.
JMS 10-20-2020
May 17, 2015 | Cars & Trucks
Instruction book for 5505e
I will send the manual to you by email, if you need
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 10, 2014 | Sanyo Office Equipment & Supplies
How do i change battery on trumeter 5505e
The device is not meant to have the battery changed (?!).
However, I am going to drill out the holes where the screws would go and try and change them myself. It doesn't not make 'consumer' sense to me to have this unit without being able to change the battery. It has a 5 year battery life but I only need this unit once in a while so in 5 years I may only use it once or twice.
Jun 07, 2013 | Cameras
How do i change the battery for the rubik's revolution? what kind of battery? thnx!!!!
It takes 3 AAA's. Unscrew the small phillips screw in one of the blue squares. The whole blue side comes straight off, but it helps if you pull off the edge with the screw first, then the opposite edge. You'll see the batteries after the side is removed. To replace the blue side, press the edge opposite the screw hole into the place first, then set down the edge with the screw hold, like closing a door. The whole blue side should sit flush against the rest of the cube. Re-tighten the screw.
Apr 27, 2011 | Pfizer Electronic Rubiks Cube Rubik's...
Need to replace the battery in a Logitech MX Revolution Mouse
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed.
NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery
Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse
As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
Sep 12, 2009 | Logitech MX Revolution Wireless Laser...
When revolution hits 2000rpm the battery LED indicator lights up
it sounds like the voltage regulator is failing under a load, i would have a parts store or good trustworthy technician test your alternator. good luck,
May 22, 2009 | 1993 Toyota Corolla
Battery
Not sure how your mouse is configured but will give you two possibilities to use.
Turn your mouse over and see if there is a small door on the bottom where the batteries are located.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 21, 2008 | Logitech MX Revolution Mouse
Computers & Internet Logo
1,003 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
