It turns on but shows carriers name and stays on that...
SOURCE: yp-k3 samsung Mp3 Screen Froze On "Remove Cable"
My daughter had a similar problem - she was frozen at the power off screen. On closer inspection, at the bottom of the K3 on the back of the unit is a reset button (you will need a pin or paper clip to reset it). Pushed a pin in for a few seconds, reset, all was OK.
SOURCE: Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
SOURCE: my phones screen is white
The problem with your phone is just
flex problem, the flex
on the screen of your phone is weak or worn out, this is a common
problem among slide or flip phone.
What you need to do is to
replace the flex on the screen of your phone, you can get this done by
going to any local phone repairer within your vicinity to help get it
fix or replace.
Once the flex is replace, your phone display
problem is solve and the screen will start displaying.
Take care.
SOURCE: I have a Samsung Galaxy
GALAXY ACE-HOW TO TURN ALARM OFF - Hi, you've probably figured it out by now but just for any other new users who are still struggling, here is the answer: Galaxy Ace : When your alarm is going off and you lose the screen option to either snooze or dismiss, simply look in the top left of the phone and you will see the little alarm icon with an exclamation mark on it, on the top bar where the signal strength indicator and the battery icon is. You can scroll your finger down over this top bar and move it down over the top of your current screen, and when the alarm is ringing, the option to either snooze or dismiss the alarm also appears on this pull down screen. Peace at last!! Hope this helps someone.....
