Question about Integra Audio Players & Recorders
I have a integra DTR-4.6 receiver. I can only get 1 speaker in each of my zone 2 areas (4 locations) to come on. This is probably something simple. Any ideas where I can look next?
Posted by Ryan Sheltra on
5 Related Answers
Anonymous
SOURCE: Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
Posted on Aug 06, 2008
Anonymous
  • 119 Answers
SOURCE: Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Posted on Mar 03, 2009
Anonymous
SOURCE: Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Posted on Jun 27, 2009
Anonymous
  • 17 Answers
SOURCE: Zone 2 speakers only work with the tuner - no
hi,
zone 2 will only work with analog sources so if your dvd, cable and other devices are connected via HDMI, that alone won't work. What you need to do is hook up RCA (red and white) cables from the dvd player to dvd in of the receiver and same thing for your satellite box (and other sources.) no need to change any setting on the receiver. This way, the HDMI will take care of your main room speakers and the RCA will feed your zone 2 speakers.
Hope this helps.
Posted on Jul 10, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Denon 1910 Zone 2 no sound
Typically, Zone 2 is for a different program than the one you're hearing in the main listening room. You can choose any source for Zone 2 EXCEPT a digital one.
Posted on Dec 29, 2009
I have a DTR 7.1 Integra receiver and it goes into protect mode when turned on. Is this something that can be fixed by myself or does it need to go to repair shop.
If you have a volt meter you may try and repair it yourself. First however disconnect the speakers and see if the set still goes into protect. If so you may have shorted output and drive transistors. There will be open resistors near them as well. You can compare the bad channel with a nearby working channel since normally only channel shorts out at a time. Always replace outputs in pairs since they in push pull configuration .
Oct 02, 2014 | Integra Dtr-7.1 Av Receiver Surround Sound...
Integra 7.8 display bad
The bad resistor is on the ps board that drives the display, well on mine at least. The resistor is supposed to be 10 ohms at 1/8 watt "i think" i replaced it with a 1/2 watt resistor. Either way its R9310. the board is right behind the display on the right side just behind the volume knob. when open and looking from the back you see it just fine. it's not hard to get out. fairly simple to fix. integra-7-8-display-bad-otccdugj0mk41z1tpuysbqy4-5-0.jpg integra-7-8-display-bad-otccdugj0mk41z1tpuysbqy4-5-2.jpg
Jul 20, 2014 | Integra Dtr-7.8 Receiver
Integra receiver clicking
You most likely have a power amp problem, disconnect all speakers and see if still does the clicking, if so you have an output amp problem
Apr 01, 2014 | Integra DTR-5.1 Receiver
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
Only one speaker working
pls. identify w/c channel is working then try switching the speakers, check your rca cords from your source player, try to switch them. th
May 05, 2013 | Integra DTR-9.1 7.1 Channels Receiver
I am missing the remote for an Integra DTR 5.3 receiver/amp. I have a Sony RM-AV3100 Universal Remote that I want to program to control it. Does anyone know where I can find the 4 digit remote code that...
Hello
Sony RM-AV3100 remote has no codes to setup with any Integra devices. You have to try its code search method. Sometimes you may find a code. But not sure. Go to the user manaul of that remote. There is proceedings for code search process. The codes are four digits indeed. OK.
Oct 09, 2011 | Integra DTR-5.1 Receiver
My left rear speaker has no sound. All others work. I have tested the speaker on a different reciever and it works fine. My reciever is a integra DTR 5.5
Swap your left and right rear speaker over. If you still get no sound from the right speaker connected to the left speaker connection on the receiver, then you have a fault on the receiver output. Check your manual first to see if any setting switch off the rear speaker before taking the unit for repair or replace
Nov 26, 2009 | Integra Audio Players & Recorders
Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Jun 30, 2009 | Integra DTR-5.2 Receiver
No output to subwoofer per-amp
you may have to go into the onscreen menu and enable it,that shuld work
May 11, 2009 | Integra DTR-8.3 Receiver
No sound from speakers from components with Integra 6.9 receiver
Turns out it had to do with one of the settings for the new Blu-Ray player.
Thanks anyway.
Jan 17, 2009 | Integra DTR-9.1 7.1 Channels Receiver
116 people viewed this question
Top Integra Audio Players & Recorders Experts
Bill DiBrino
Level 1 Expert
Naheed Mir
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
