Some dehumidifiers with the model number, FAD504DUD, are subject to a recall. Record the serial number and then go to https://www.recallrtr.com/dehumidifier to check if your unit was manufactured in the bad batch.
I understand that your Frigidaire dehumidifier, model# FAD504DUD, is freezing up. First, if your dehumidifier has been turned on recently, this is normal due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Secondly, make sure the room temperature is above 41 degrees Fahrenheit. If it is too cold in the room, the coils can freeze. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
Good Afternoon Tad, thank you for allowing me to assist you!
First remove the bucket to reach the filter of your Frigidaire dehumidifier, FAD504DUD. When you locate the filter, pull it downwards. The filter can be clean by either washing it with clean water or using a vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once the filter is reinstalled then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier will resume normal operations.
