Question about Sharper Image Air Purifiers
SOURCE: SHAPER IMAGE OUT OF BUSINESS
Sharper Image has recalled all Ionic Breeze Ionizers. This is what put Sharper Image into chapter 11.
For information see the link
See the EPA link as well
Posted on Jul 12, 2008
SOURCE: Sharper Image Hybrid GP Germicidal Air Purifier SI724 NO POWER
Oh there are a lot of known issues! I used to work for sharper image and I believed in this items very much so until mine broke. However after a year I figured out how to fix it. Take the big square collection grid out and the back screen off. Now get you a thick rag and be very careful because there are several tiny wires going up and down. Smaller than dental floss, you need to be very careful because you can either brake them or slice your finger wide open( Under any circumstances I can not be held liable for the information I am giving you try this at your own risk). Now with the towel very gently go up and down each wire like you are polishing a brass pole(once again these wires are thin and can break or cut you). Do this from the back side of the unit and from the inside where the collection grid that you took out sits. Take your time and be thorough, and presto your 400 dollar air cleaner is working again.
Posted on Nov 26, 2008
SOURCE: I have a sharper image
If the warranty you are counting on is a Sharper Image Warranty I need to advise you that it was voided in the buyout on 30 May, 2008 when everything at Sharper Image was liquidated by Hilco Consumer Capital, Gordon Brothers, and Bluestar Alliance. If however it was a warranty company outside of Sharper Image you need to contact them.
You can purchase a bulb for the GP on ebay for under $11, which is really a good price considering what you would have paid from Sharper Image. Installation is easy, you just pull up on the tab on the bottom of the filter and pull up. When you are looking at the bulb, turn it 1/4 turn, (2 clicks) and pull it out. That is all there is to it. Hope this helps you.
Posted on Jul 04, 2009
SOURCE: Need replacement grids for Sharper Image Model
Replacement grids have been posted to ebay. You can replace the complete unit for $45 on ebay so that would probably be a better solution. The last grid I purchased on ebay for similar was around $20.
SOURCE: I have an Ionic breeze GP from Sharper Image and
ebay item number:220444965077
$10.99 plus about $5.00 shipping. They have a phone number posted also. The bulb is easy to replace. Reply to this post if you require instructions.
