Question about Locks & Locksmithing
E HAVE A MEILINK9618MLOC8NEED COMBINATION DO NOT HAVE KEY TO SET OR CHANGE COMBINATION
Posted by CARL BLACKETER on
How do I change the combination on my Unican 1000 keyless lock? thx john
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
Changing the Code/Combination
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I WANT TO CHANGE COMBINATION ON MY SENTRY FIREPROOF SAFE HOW?
I have a sentry safe csw 4747 Idont no tha combination
how do I do the safe a key and electronic key pad
Jan 11, 2010 | Sentry Fireproof Safe
Need to change password from previously changed password
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network
Click Here for more info
Dec 19, 2009 | 2wire 1800HG Router (RG1800HG00)
Ntel(R) Wireless WiFi Link 4965AGN i want to
Wireless Security
WPA
WPA2
Once you change the wireless settings on the router , try to connect to the new wireless network .
Dec 16, 2009 | Computers & Internet
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
I want to change my Master Lock combination
open the shackle twist 180 degrees...shut it as if u were closing it into the locking device..hold it down, put in what ur new combination is..pull the shackle up and shut it into locking device, and test it out.
Jan 25, 2009 | Master Lock 5400d: Portable Select Access...
Erased the code
FOR YOUR SECURITY THE
COMBINATION MUST BE CHANGED
WHEN THE LOCK IS INSTALLED.
position (A) (see figure 14-1).
combination change plug assembly (C)
key counterclockwise. Remove the combination
14-1).
2. Turn the outside knob once clockwise
14-4).
installations, use the factory-set combination:
(release), then 3 (release). You should
depressed.
Figure 14-2 to engage the combination
then turn the spanner wrench counterclockwise
14-3). Remove the spanner wrench.
5. Turn the outside knob once clockwise all
latch should not retract (see figure 14-4).
on page 26, then enter the new combination
— depress buttons care-fully
Dec 08, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
My master lock 1547 lock combination was changed and i cant open it
If you have the change key, you can insert into the lock and make a new combination. Only the Change Key witll allow you to change combination.
Artgirl
Jul 16, 2008 | Master Lock 5400d: Portable Select Access...
Locks & Locksmithing Logo
176 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
