Question about Lexmark X3470 All-In-One InkJet Printer
Lexamrk X3470 printer SWITCH KEPT SAYING COVER OPEN
PROBLEM WITH THE SWITCH : KEEPS SAYING COVER OPEN
Posted by karinelke on
Soulvisitor
  • Lexmark Master
  • 1,113 Answers
Anonymous
Smash the POS with a hammer and go buy something else
Posted on Dec 12, 2007
Open cover problem
You have go to service, becouse the switch for cover is brouken, and they need put them ih close mode. In same primter model switch is in diferent placeses
Sep 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470
Try looking around the edges of the cover or in the hinge area for a switch that may be stuck. Most covers have a switch to indicate that the cover is open, the cover may not be seated properly or the switch may be stuck in the open position.
Aug 30, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Good luck...
Mar 26, 2009 | Lexmark X3470 All-In-One InkJet Printer
Series 3400 printer
If your printer still in warranty please replace the printer or This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located..
Good luck....
Oct 30, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 has cover open in display will not do anything now
you need to open cover and undo and remove the grey cover inside the printer as there is a switch at back of machine which has *** off
Sep 29, 2008 | Lexmark MFP-X3470 All-In-One InkJet...
Cover Open
http://www.fixya.com/support/t235147-lexmark_x_3470 It helped me I got mine working just follow the instructions and especially the pictures when you scroll down.
Aug 14, 2008 | Lexmark X3470 All-In-One InkJet Printer
Cover door open Now paper wont pull down or jams
Sounds like something stuck in paper path, check paper feed area for any obstructions.
Dec 29, 2007 | Lexmark X3470 All-In-One InkJet Printer
COVER OPEN
There is a plastic lever in the back of the scanner where it comes into contact with a part made to push the lever when closed to work the switch. It is a poor design. The lever fits over the small micro-switch very loosly and the tabs wear out really quick. Lexmark will not send another lever. They state buy another printer. If you are real careful, you can put the lever back on the switch and hold it in place while you close the lid.
Oct 27, 2007 | Lexmark X3470 All-In-One InkJet Printer
Cover open error
plesase check the cover sensing switch or sensor
Sep 21, 2007 | Lexmark MFP-X3470 All-In-One InkJet...
Lexmark X3470 All-In-One InkJet Printer Logo
123 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
