Vacuums Logo
Question about Bissell Vacuums
Retractable cord on bissell vacuum keeps retracting, how do i fix it.
Posted by jeanne on
5 Related Answers
Anonymous
  • 625 Answers
SOURCE: Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Posted on Aug 20, 2007
Anonymous
  • 30 Answers
SOURCE: retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Posted on Mar 08, 2008
Anonymous
  • 7 Answers
SOURCE: vacuum wand won't retract fully into it's compartment.
HI,
FIRSTLY DETACH WAND FROM UNIT AND SLIDE HOSE DOWN AS FAR AS IT GOES, SPRAY A LITTLE WD40 OVER WAND AND SLIDE HOSE UP AND DOWN, AS FOR THE CAP, TAKE A PAIR OF PLIARS, GRAB HOLD OF END OF CAP AND PULL CAP FULLY OUT OF THE HANDLE,AT THIS POINT CHECK THE SPRING OR REMOVE THE SPRING IF YOU PREFER AND PUSH THE CAP BACK INTO HANDLE AND THAT WILL DO IT FOR YOU.
REGARDS
DAZ
Posted on Dec 13, 2008
Anonymous
  • 44 Answers
SOURCE: Power cord will not retract on my Electrolux UltraLux 2000
You will need to take the machine apart to correct this. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come off relatively easily, and everything will be exposed. Now, assuming that the cordwinder isn't damaged, you should be able to wind the cord in by hand. Once it gets started it may start to retract automatically. Usually the spring just gets in a bind against the housing when it's over extended, and rolling it in by hand a little will free it up. Good Luck!!
Posted on Jan 05, 2009
ukvacfan
Ryan S
  • 328 Answers
SOURCE: electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
Posted on May 08, 2009
1helpful
Cord retraction
You may have to replace the cord reel. First inspect it thoroughly to see if you can find something restricting it from retracting.
Apr 15, 2018 • Vacuums
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Bissell Hard Floor 1161 Bagless Canister Vacuum cord won't retract
You have to find a way to turn the drum the cord rolls up onto. Just move it par enough o allow it to retract. Hopefully you will hit that point before the spring lets go.
2answers
Cord won't retract or pull out
No, but we have a great network of warranty repair centers. You can find one near you at this link:
How to disassemble to repair cord retractor?
If you have a BISSELL rewind vacuum you can take a look at these simple tips or take it to one of our Authorized Service Centers: http://www.bissell.com/FAQDetail.aspx?id=8991&cid=ccsocial
Apr 24, 2012 • Vacuums
2helpful
I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Feb 12, 2011 • Vacuums
1helpful
Cord won't retract or pull out. It is out about half way.
  • This is a common problem with retractable cords. Now because yours is not all the way pulled out you may be able to get it to go back in by giving it a quick **** on the cord. Not a long pull , but a quick tug! and it may release the jam. If not it will need to come apart and fixed. I will need the make and model in order to give you step by step instructions on this. Bissell makes many different makes and models and they are all slightly different from one another. so if this works for you great, if not write back with the make and model and I will give you step by step instructions on how to do this.
The automatic cable rewind on my Morphy Richards pod vacuum cleaner keeps retracting. I'd rather it didn't work at all than be constantly pulling out the cord. Is there any way in to fix it or disable it?
Hi Not really. It means that the cord has been pulled roughly when its been plugged in and the retracter is getting weaker to hold the cord that has been pulled out. Generally though wipe the entire cord from the end of the machine with a dry cloth and some furniture polish. This will clean the cord and add some resistance to the retractor that could minimise the cord flowing back into the vacuum.
Retractable cord
1helpful
Sebo K 3 Vacuum
I had a problem with my K1 Komfort model which sounds similar to this. I initially thought the cord was too short but the machine wouldn't give out anymore and retracting was difficult. A Sebo engineer/helpline told me to pull roughly on the cord, of which I did and was rewarded with 2 metres more than what I thought I didnt have! So, perhaps if your machine isn't retracting properly, give the cord a rough pull with gloves on, or a strong grip - the cables on the K series are notorious for stopping up. Afterwards wipe the entire cord down with furniture polish; it will retract much more quickly.
Top Bissell Vacuums Experts
Marvin
Marvin
David Shaub
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
