Question about GE Kitchen Ranges
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Posted on Oct 04, 2017
SOURCE: the digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Posted on Jan 14, 2009
SOURCE: Change watch setting from 24 to 12 hr clock
my 40/6703 has 4buttonstop left-light topright-st-stp bottom left mode bottom right reset can u help
Posted on Jan 31, 2009
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Posted on Feb 21, 2009
SOURCE: How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Posted on Mar 22, 2009
SOURCE: Changing from 24 hr system to 12 hr system
Posted on Jul 07, 2009
Hi Ann Feldman, we want to help you with your question, but we the model number ?
need more information from you.
Can you please open oven door and see if model number is on the front of oven stamped into the front side on right hand side of oven when it is opened ?
add details in the comment box?
