Question about Bunn Coffee Makers & Espresso Machines
When was my Bunn coffee maker date code 160308 manufactured
Posted by Lisa Oxner on
5 Related Answers
Anonymous
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
Gord Thurston
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
atbsmmom
  • 189 Answers
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Posted on May 19, 2010
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
wesleyb
  • 4 Answers
SOURCE: I have a Bunn coffee
The manual for this coffee maker can be found at this link:
http://manualheaven.com/assets/bunn-nhbx-b-contemporary-coffee-maker-manual.pdf
While the manual does not contain repair instructions, it does have some troubleshooting tips to follow if your coffee is not staying hot.
Posted on May 04, 2011
How to contact Bunn regarding a water leak in my coffee maker
Search Bunn O Matic on google, look for tech support.
Sep 29, 2014 | Bunn 10 Cup Home Coffee Brewer
I have a Bunn coffee maker with date code of 401406. It is almost 4 years old and still brews perfectly. The warming plate does not heat up any longer so the coffee will not stay warm after it is brewed....
May 04, 2011 | Bunn NHB Coffee Maker
Bunn coffee maker model gr10-b water will not heat in tank
If you will call customer service with the model and date code at 800-352-2866 we will be happy to help you with this issue.
Oct 17, 2010 | Bunn B10 Coffee Maker
My bunn bx-b leaks onto counter
Do you have the code date? If the machine 3 years old or less, it will be replaced free of charge for you. Please call 800-352-2866 with the model and code date and customer service will be happy to assist you.
Sep 20, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
I have a Bunn coffeemaker and it is not that old. It leaks from the bottom when you fill it with fresh water for a new pot of coffee. The number is NHB code date is 204305. Do you have any ideas?
The brewer probably has a bad seal or gasket. By the date code, your machine is 5 years old. If you call Bunn Customer Service they will be able to offer you an exchange of your old brewer for a new one at a reduced price.
May 29, 2010 | Bunn NHB Coffee Maker
I have a bunn coffee maker the nhbx is the # it is leaking water from the resevoir
May 12, 2010 | Bunn NHB Coffee Maker
Bunn 10 cup home coffee maker
It sounds like a seal/gasket is defective causing it to leak. Please locate the model and date code on the bottom of the brewer and contact customer service for troubleshooting and replacement options.
Feb 05, 2010 | Bunn 10 Cup Home Coffee Brewer
Apr 29, 2009 | Bunn 10 Cup Home Coffee Brewer
Basic Bunn Coffee makers will not light up
look on the left hand side down by the bottom there is a switch try that.
Feb 12, 2009 | Bunn GR10 Coffee Maker
Coffee Makers & Espresso Machines Logo
527 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
