Quick-Change Blade Mechanism
Higher-end models, such as the Linefinder Orbital Jigsaw, feature a clamping lever to hold the saw blade. To change a blade, switch off the jigsaw, unplug it, and let the used blade cool down. Pull up the saw-blade locking lever and let the used blade fall out with a slight shake. Turn the jigsaw upside down. Hold the fresh blade with its teeth forward; insert the blade shank into the blade holder as deeply as it will go. Release the lever and wiggle the blade to confirm that it's snugly in place. For models with rollers, such as the Accu-Trak, nestle the blade against the rollers.
Clamp or Hex Screws
Loosen the pair of screws -- on the front of the mechanism of models such as the single-speed jigsaw -- a full turn counterclockwise with a flathead screwdriver, but do not remove them. The used blade will fall out. Insert the new blade fully into the clamp. Lightly tighten each screw alternately and then fully. On older models, you may find a single hex screw on the side of the blade. Loosen this enough to remove the blade, and then insert a new blade carefully so the teeth face forward. Retighten the screw.
UNPLUG TOOL. To remove the blade, lift the knob on the top of the jig saw approximately 1/4".
Rotate the knob counterclockwise until the clamp is open (Figure 8a). Do not force the knob once
it stops. Insert the blade as shown. Make sure the back edge of the blade fits into the support roller.
Tighten clamp by turning top knob clockwise until you hear a click. Push knob down.
For "T" shank blades, insert blade to the shoulder of the shank.
Look at manual on the link below.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf
Good luck please rate 4 thumbs up and please leave a testimonial
