Question about Dual Video Game Consoles & Games
93 Buick lasabre limited no air through vents from blower fan
Dual digital control
Posted by Travis Clark on
5 Related Answers
Anonymous
  • 37 Answers
SOURCE: Blower motor vent selection switch not working
the hvac selector switch in the dash may be the problem.You need to remove the switch and look at the connector on the back of switch,see if there are any burnt wires at the connector or switch.It's all electronic and the switches have been known to burn out on this and other model.
Posted on May 26, 2009
WESLEY SCHACHT
  • 57 Answers
SOURCE: Air conditioner/heater blower fan on 1997 Buick
it will be hard to diagnose with out having my hands on it but try this.
this vehicle is known for blower motor resistor failure.
under the dash on the passenger side next to the blower motor there is a resistor attatched to the blower motor case it will have a single plug with 5 or 6 wires in it, they are normally within a couple of inches of the blower motor, remove this resistor and look at closely for any signs of burning this is a common problem, you can buy one at any parts house, do not operate the motor with the resistor removed from its mounting hole or you will damage it.
if the resistor looks good than purchase you a test light and drop me a line and i will explain how to test the entire system its not hard to do.
[email protected]
Posted on Jun 14, 2009
michael_grey
Michael Grey
  • 365 Answers
SOURCE: 2001 Buick Century Limited air conditioning situation
It sounds like a actuator is bad or not getting proper vacuum to open or close on demand.
Posted on Jun 17, 2009
Anonymous
SOURCE: AC/heater blower/fan is not working.
when i turn the ac on the fan is very loud like there is something in it or it is about to go out
Posted on Aug 16, 2009
gm-tech 561
  • 41 Answers
SOURCE: our 1998 buick lasabre air condioning will not
ck to see if your vaccum hose if broken at the engine vaccum connection, it may have a vaccum hose split or a bad vaccum switch/actuator, if it has manual a/c, if it has electronic a/c then your mode actuator is not working.
Posted on Aug 10, 2010
Where is the fan(blower control module) located on a 1993 Buick LaSabre the fan motor runs on high all the time even with the key off. this car has the automatic A/C-heater system
The blower control module is located under the hood along the firewall.It is about a foot from the blower motor.(more towards the passenger side) It is harder to see as the relay center is directly above it.
Jan 06, 2011 | 1993 Buick LeSabre
I cannot get air out of the mid vent on my 1998 lasabre Limited. I don't think the problem is with the dash hearter a/c controls. Any ideas?
IT IS YOUR BLOWER MOTOR. CHECK TO SEE IF YOU HAVE A FUSE FOR IT. IT IS LOCATED UNDER YOUR DASH. YOU MIGHT BE ABLE TO TAP A LITTLE ON IT. IT MIGHT WORK. BUT OVER ALL YOUR GOING TO NEED TO REPLACE THE BLOWER MOTOR.... JAKE.B
Jun 16, 2010 | 1998 Buick LeSabre
Heater/A.C. fan motor will not shut off on my 1992 buick lasabre limited
you must have automatic climate control. the fan module is at fault. you need to replace it for these are not repairable sealed units
Feb 18, 2010 | 1992 Buick LeSabre
May 26, 2009 | 1998 Buick LeSabre
Air blower will not run on high
It's heater controls r in limp mode,need to replace temp. resistor,located in heating ducts somewhere not familer with that exact model
Mar 10, 2009 | 1997 Buick LeSabre
Video Game Consoles & Games Logo
64 people viewed this question
Top Dual Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Dual Video Game Console and Game Expert? Answer questions, earn points and help others
