SOURCE: I cant disarm my alarm
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
SOURCE: 1995 Nissan Maxima alarm system
Hey, I bought my 1995 Nissan Maxima GLE brand new back in July 1994 with factory installed alarm, it just doen't make any sound when you arm or disarm it with remote. The only way you can tell whether it is armed or disarmed is from the lever position of your doors and the blinking red light under the dash. Only the newer versions of Nissan/Infiniti's has the "Audio/Silent" mode button on the remote which allows you to activate/deactivate you car alarm with an audiable sound or no sound at all. No worry, there is nothing wrong with your remote or car alarm.
SOURCE: Toad car alarm - text alert texts when arming and disarming alarm
yes this is aknownprobplem to Scorpion (Toad), you will need to use relays on the trigger wires
SOURCE: viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
SOURCE: ford factory alarm arm output and disarm output
I don't show this truck as having a factory alarm, is there maybe an aftermarket alarm in it
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
