Question about Locks & Locksmithing
My E-plex 2000 lock won't let me enter new access codes when in push-button mode. Dows any one know how to fix this
Posted by Jamie-Lee Shaw on
4 Related Answers
Anonymous
  • 74 Answers
SOURCE: Kwik Set keyless entry lock. We
With the door open so u dont get locked out,did u remove the batterys and try to re-set your door code ?
Posted on Dec 18, 2010
emissionwiz
Marvin
  • 85239 Answers
SOURCE: my girlfriend dissconnected the battery in my car
If you can't remember the lock out code then you must contact the manufacturer for an override code, we can't supply that. They will most likely require proof of ownership. Thanks
Posted on Mar 23, 2011
Coaltowner
  • 963 Answers
SOURCE: We have installed a KABA
Programming instructions for your lock can be found here:
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Good luck--and please provide feedback if this helps!
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on Nov 05, 2011
Coaltowner
  • 963 Answers
SOURCE: kwikset smartcode deadbolt newly installed unlocks when lock button pushed. I have taken batteries out and reset few times with no success.
"I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?"
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
These instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
These locks are made to work on a door which, when you stand outside and face it, has its hinges on either the left-hand or right-hand side of the door (= door "handedness").
The jumper controls that for the appropriate installation. Yours is set wrong!
Posted on Jul 12, 2012
My keypad won't light up when door is locked whe you push lock won't light up green
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Cannot get it to accept the user pin numbers. Have entered the master code and also reset the manual reset to default.following the manual and using the # sign before and after master code. red light comes...
Recommend that you contact Kaba Ilco with your problem.
Jul 01, 2011 | Simplex Kaba E-Plex 2000 series Keyless...
I have reset my E-Plex 2000 to factory Default BUT the master code 1,2,3,4,5,6,7,8 doen't work. Why?
why dont you tell your wife to stop locking you out and changing the password .. and tell her to stop calling me
Apr 23, 2011 | Simplex Kaba E-Plex 2000 series Keyless...
I got a 2000 Ford Explore that I got about 5 months ago. I don't know the codes on the door to unlock it. how can I get the codes or reset it.
You will need the original factory programmed keyless entry keypad code to program your own code. To locate the original keypad code, open the right/rear door. Pull the on-body rubber weatherstrip out, around the rear side of the door closure. Fold the right/rear seat back down into the locked position to facilitate access to the right/rear seat belt anchor. Carefully pry the upper plastic panel that houses the height adjuster and seat belt anchor off the body taking care not to damage the panel. Now pry the lower panel outward just far enough to enable access to the Vehicle Security Module, where you'll see three electrical connectors plugged into it, colored green, gray, and blue. On the module will be a series of digits on a label similar to 2L2T-15K602-EA. Beside those digits are five numbers. Those five numbers are the key-less entry keypad code. Once the original keypad code has been obtained, you will need to enter it, press the 1/2 button within 5 seconds to activate the programming mode. Holding the 1/2 button for more than 2 seconds after activation will erase the the code you programmed. The existing code will not need to be erased to program a new code. Within 5 seconds, enter the new 5-digit keypad code. The door locks will lock and unlock to confirm the new code is programmed. Hope this helps Tim
Apr 06, 2011 | Ford Explorer Cars & Trucks
We have installed a KABA E-PLEX 2000 with several access codes and too many people have aquired the codes. We wish to wipe out all the codes and start fresh. We were given a master code but are unable to...
Jan 11, 2011 | Simplex Kaba E-Plex 2000 series Keyless...
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
How do we reset the door code
From this page you can download the manual necessary to reprogram your 2000 series:
http://www.kaba-ilco.com/access_control/literature/literature_grid_eplex.aspx?id=14&obj=2000
You have two choices when you mouse over "manual" for the 2000. Each is a PDF file: you can download Adobe Reader from the link on the same page.
Dec 28, 2010 | Simplex Kaba E-Plex 2000 series Keyless...
How can i program my door lock code or find out what it is. on my 2000 limited edition explorer
FORD KEY PADS
  • Enter permanent factory code
  • Press the 1/2 button within 5 seconds to enter programming mode
  • Within 5 seconds enter new code, doors will lock, unlock to verify code, this erases previous codes remotes will also need to be programmed.
FORD KEY PADS/REMOTES
  • Insert key, turn ignition off-to- on eight times in succession, ending with key in on position doors will lock, unlock to verify in programming mode
  • Press any button on new remote, doors will lock, unlock to verify
  • Do the previous step with the second remote, doors will lock unlock to verify.
  • Turn ignition off. Doors will again lock, unlock to verify.
NOTE-I found that some Explorer/Mountaineers enter program mode after 5 times-not 8.
Here is the link for further info.
http://www.2carpros.com/how_to/how_to_reprogram_key_remote_fob.htm
Your factory code is on a card in the owners manual. If that is lost, access the control module in the cargo area behind the left cover panel.
You MIGHT be able to see the code printed on it, or you might need to pull it out in order to see it.
May 27, 2010 | 2002 Ford Explorer
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
enter the service mode
f9
enter
Apr 02, 2010 | Panasonic Workio DP-2000P Copier
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Locks & Locksmithing Logo
352 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
