SOURCE: printing
Likely your purge unit needs cleaning...
Make sure by printing out a test page from printer (not from computer).
If test page is good, you have a software issue. If test page is bad, you need to clean your head and/or purge unit.
SOURCE: can't rotate ink cartridge to change
Read some of the other problems and answers and found out how to move the cassettes around manually.
Press a little spring loaded button beneath an oval hole to the left of the cassette removal hole with something like a key or flat screwdriver. This enables the cassettes to be moved around manually anti-clockwise until the one that needs changing is in position. Then just carefully pull it out. Push in the new cassette after rolling and rocking to ensure the toner is distributed as advised in all instructions.
This method is actually much easier that trying to do it from the software in your your PC or Mac. Don't know if it means that some things are not reset - but it worked perfectly for me. In fact once I knew how, it was the easiest cassette change I have ever done........!
SOURCE: Reset the ink memory level after replacing cartridge
Have you tried to unplug your printer and plug it back in?
SOURCE: Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
SOURCE: HP Deskjet 54280 won't print
Try cleaning the print heads. You can find more troubleshooting info in the manual:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
