Question about The Audio Players & Recorders
Blackweb model BWA16AA002 As the CD player was playing and the volume was at around 24ish the sound stopped! No sound after that on cd, radio or BT. Any ideas? It was less than a year old.
Posted by Amir Aghassi on
Lawrence Oravetz
  • The Master
  • 10,548 Answers
Sounds like the amplifier output transistor fried.If it's still under warranty, try getting it repaired with the warranty. If not, then a local repair shop probably can fix it.
Posted on Oct 03, 2017
5 Related Answers
Anonymous
  • 77 Answers
SOURCE: CD Player doesn't work; says "disc"
i would say that your lense is dirty and yes cleaning it might help
Posted on Feb 11, 2008
josh markham
SOURCE: 2004 Chevy Trailblazer radio and CD player works, but no sound
if you have installed a new cd player in there then the propblem could be that your speaker wires and either touching each other or grounding them selfs out.. pull of the cd player and check to make sure all the speaker wires are covered properly and no bare wires are exposed.. if you still have a factory cd player in it then you will probably need to take it to a dealership to have it checked out..
Posted on Feb 23, 2009
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Posted on Jun 28, 2009
Anonymous
  • 66 Answers
SOURCE: CD player on Bose radio started making a click sound
did you clean the laser inside? that a thing I would do first
after that mail us again
Posted on Feb 15, 2010
chylde2003
SOURCE: i just hook up an
The Reason The Cd Won't Play is because You must connect the remote amp wire from your after market stereo to the ant. power wire. Then the CD will have sound!
Posted on Sep 01, 2011
CD player doesn't work on Timex Indiglo Radio Sounds CD player. No manual available. Can't use.
I never have seen this model but guess it's similar to any other CD-Radio model. You can download a manual from here
https://timexaudio.com/media/uploads/product/files/T618_IB59176_84.pdf
It should have a switch to select CD player.
Once you select CD player, open CD lid, insert a CD and play
If won't play, CD player is defective and if you don't know how to repair it you should take it to a repair service and evaluate if it's worth to reapir.
1986 Thunderbird, cd player keeps cutting off. Is this power problem?
No that sounds like the player is just old and most likely needs the tiny drive belts replaced.
My KD-NX5000 has suddenly stopped playing all audio sources. CD's or DVD's start up and the timer shows that CD is playing but there's just no sound. The sat nav works as it should. Haven't...
Did you ever get this fixed? I'm kind of having the same problem, my radio works but nothing else is. I can hear music on the radio but when I switch to cd or bt (iPhone) ... I hear nothing thought (cd) it recognizes discs and I can see them play but no sound. It played before till one day it stopped. I don't know what changed or was set differently.
I have an MC 602 and can not change the source-it constantly reads Tape; the power goes on and off, the house chimes work but I can insert a CD, it plays but there is no sound and I can not switch to the...
Had the same problem. Tried rebooting the system. Nothing worked. Saw another post about speakers. Went around the house and turned volume down and it started working by time I hit the third room. weird stuff.
How to record a cassette from cd on a sony xplod boombox cfd-g505
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDG505
2answers
Denon DNS1000 distorted/fuzzy sound
Please visit www.denoindjforums for further help.
3helpful
10-year-old Kloss, model 88 stopped playing, suddenly.
Sounds like a cold dry joint connection problem internally ,needs to be serviced
Sound volume
i do not know what iwill to say
2answers
Bose radio
Not on its own, but you could connect an external CD to the auxilliary (AUX) RCA/ phono inputs on the back evn a cheap, personal CD player could be connected from the line out / headphone socket! (If you do this from the headphone socket, make sure you only have the CD player set to about two thirds volume or the sound will be distorted and poor)
Top The Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Paul Carew
GLESGA BOY
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
