BIOS weather 315BC-TX manual. I see a little switch [3 2 1] which situated under a batteries cover of an outdoor transmitter. you'll see this switch inside if you unscrew the cover of the batteries box What the switch for?
SOURCE: BIOS Battery
After spending a couple of hours looking for the cmos battery I found it. It is located underneath the mouse keypad. To access it you must unscrew the front bottom of the laptop and be able to seperate to top and bottom portion of the laptop. On the right hand side you will see a pocket inside is the battery. I hope this helps.
Iamtech1
SOURCE: A/C will not turn off
you need to replace the controll station this is a common problem on the ranger the controller seems to send a signal to turn on the air con compressor go to the scrap yard and get the correct controll panel and replace it alot cheaper than the oem unit from the dealer at 195.00 here in canada so give that a shot or wire switch direct to the 12 volt compressor clutch wires alot cheaper good luck waiting to hear more re issue
SOURCE: Can I use the Intermatic EJ500CH timer in an outdoor box?
No as long as the box is well insulated.
The operating temperture must not fall below - 5
SOURCE: dashes in my outdoor weather reading of Oregon Scientific station
The signals are not being received by the main unit. Try to reposition the unit or move it to a different location. Also make sure the antenna is in the clear and not next to any thing like a cordess phone or charger as these can make RF noise that can block or cover the needed signals.
