Question about Casio Music
Cd rom software for casio wk-110 where can i get the cd that comes with a casio wk-110.
I am trying to find the cd that comes with a Casio WK-110 Musical Keyboard.
Posted by John Barrometti on
James Kovacs
    Champion:
  • 219 Answers
From CASIO, duhhh ?
Posted on Dec 14, 2017
5 Related Answers
Anonymous
SOURCE: I purchased the Casio Wk-1800 in 2000. Moved
no but can't afford to join any plan
Posted on Jun 25, 2009
Tim Swiercinsky
  • 1126 Answers
SOURCE: How to save setting changes on Casio WK-500 keyboard?
This is a link to WK-500 owners manual.....SD Card information is on pages E-59 thru E-64...
http://support.casio.com/pdf/008/WK200_500_e.pdf
Posted on Oct 22, 2009
Fred Yearian
  • 5603 Answers
SOURCE: My WK- 3700 Casio keyboard is malfunctioning.
One portion of the key scanning matrix has gone bad. First thing is to clean the contacts with 99% isoprophyl alcohol. These USUALLY consist of traces on a circuit board that conductive rubber "pills" under silicone rubber domes are pressed down. Each note usually has two contacts, one closes before the other. This creates "velocity" measurement for the key. IF ONE of the contacts for a key doesn't work, the velocity can detect that the note has actuated, but no release occurs.
This would be on the "STROBE" line for either the first or second contact for THE OCTAVE you have problem with. There are disconnect diodes that prevent sneak paths.
You could have one bad diode, a crack in the circuit board, or a bad connection to the keyswitch board.
Posted on Nov 27, 2009
Andrew Conroy
  • 298 Answers
SOURCE: How do you replace the adaptor jack on a Casio
Unfortunately the adapter jacks are a bit of a weak point on many keyboards but it is quite seldom the jack socket itself that is at fault.
Often the sockets are soldered directly on to the printed circuit board and are prone to either one of the soldered legs breaking, or even the circuit board itself cracking around the jack socket.
Whilst it is generally possible, with care, to resolder a broken leg on the socket if the actual circuit board has cracked the whole board will have to be replaced.
If the actual jack socket itself is damaged it should be possible to snip through the legs and remove it before soldering a new one on to the stumps of the old legs. this is likely to prove easier than trying to solder directly onto the circuit board, unless this is something that you are experienced at doing.
Apparently you can purchase a full service manual for the Casio WK-1200 here for a modest price but I have not used this source myself so cannot vouch for how good it might be.http://www.tradebit.com/filedetail.php/2084335-repair-manual-casio-wk-1200-electronic-keyboard
Posted on Feb 02, 2011
Testimonial: "Thanx, I found this most helpful"
Fred Yearian
  • 5603 Answers
SOURCE: Where can I get a replacement power
Here is one:
http://www.amazon.com/Casio-AD-12MLA-Adapter-Power-Supply/dp/B00029HDT0
and another, less expensive on Ebay:
http://cgi.ebay.com/Genuine-AD-12MLA-12V-2-5A-2500mA-AC-PowerSupply-ADAPTER-/390280683299?pt=LH_DefaultDomain_0&hash=item5ade8a9f23
Posted on Feb 25, 2011
Testimonial: "Many thanks - am in UK but was able to find similar item here."
When I plug in stereo headphones in the casio wk 210, the sound only comes out of one ear. I didn't really care about that before, but now when I connect a line out from the piano to my computer to...
The output of the casio may only be mono, you can buy splitters to create a 2x channel output. Is there any other outputs from the casio other than headphones, usually there are red/white RCA outputs (Phono's) which would be better for connecting to your soundcard.
Hope I was of use to you, good luck.
Aug 04, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
How do you replace the adaptor jack on a Casio WK-1200 keyboard ? is it easy ?
Feb 02, 2011 | Casio Music
I have a casio wk-200 piano. I bought headphones
The keyboard has a mic jack that is the same size as the headphones. You probably put the headphone plug into the wrong jack is all.
Jan 10, 2010 | Casio Music
Where in europe can I buy an adapter for the casio WK-110 keybord
The specs for the adapter are:
9 volts DC
850 ma MINIMUM
Center pin of connector NEGATIVE
If you find an adapter meeting these specs it should work, however I would recommend getting a regular Casio unit. They are under $20 USD and the part number is AD5.
Jan 02, 2010 | Casio CTK810 61 Key Keyboard
Oct 22, 2009 | Music
SMF converter for wk-500, Does it exist?
No.
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Dec 31, 2008 | Casio Lighted Keyboard LK90STADMC
Music Logo
81 people viewed this question
Top Casio Music Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Tim Brauer
Tim Brauer
Are you a Casio Music Expert? Answer questions, earn points and help others
