On most machines, the outer knob on the handwheel needs to be turned counter-clockwise to disengage the needle during bobbin winding. Your machine may have a safety that prevents bobbin winding while the needle is engaged,.
How to wind Bobbin on Bernina machine MPG
Is the bobbin pushed over to engage the stop
SOURCE: Bobbin winder is in operation mode
Ive done that already, didnt change anything.
My husband figured it out... It turns out that the metal pin used to keep the bobbin in place while its spinning was stuck and wasnt out completly, making the machine think there was a bobbin on the winder even if there wasnt.
SOURCE: Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
SOURCE: viking sewing machine 545 bobbin stuck on rewind
Most machines you slide the bobbin winder to the right to wind and then back to the left when your done to remove. Just making sure.... you did move it back to the left?
SOURCE: bobbin will not rewind
SE270D. Lift the bobbin and reposition, making sure it is down against the pin.
If this is not the problem, a Sidewinder Bobbin Winder (auxiliary bobbin winder sold with most sewing notions) is a lot cheaper than taking the machine in for service.
SOURCE: The machine is beeping and does not start. It
Is your button hole lever down? I had the same problem after sewing a button hole and couldn't figure out why I couldn't return to normal sewing. Once I raised the button hole lever the machine worked again.
