Question about KitchenAid Dryers
No heat from KitchenAid KGHS01PMT0 dryer. All other functions work except I can't change the amount of heat
    Top Expert:
  • KitchenAid Master
  • 6,289 Answers
Several things could cause that. Heating element, improper voltage, fuses and thermostats, timer, burnt wires, and motor are all possibilities.
Posted on Oct 01, 2017
6ya staff
SOURCE:
Levi Holiday
  • 68 Answers
SOURCE: KitchenAid Gas Dryer wont heat everything else
Does the dryer heat at all? turn you dryer on for about 1 minute then open the door, any heat? yes= check to be sure you venting is good and clear. if good then you have 2 common issues i would check first. the thermal fuse could be blown or the gas valve coils could be bad. give me you model number and i can give you more suggestions of what to check and how
Posted on Mar 22, 2010
Alex
  • 30 Answers
SOURCE: I have a kitchenaid electric dryer. The model
check thermostat first (it have about 5-8 of them inside) check on continues. if this all of them fine, the you have to check heater on continues too.
also if this is electric dryer check if you have 240v in power outlet.
all of this involve some kind of experience with electricity do you should be careful or ask professionals www.appliancesrepairla.com
Posted on Jun 26, 2010
rickead1
Rick Ead
  • 1998 Answers
SOURCE: the dryer heat is not
it could be a hi or low thermistor or a run relay or the heater itself. All these parts you are able to check by conducting continuity tests on each piece, make sure the unit is unplugged when you conduct this test using a multimeter. Which ever piece showed having no continuity would be the one that was at fault make sure you also unplug one of the wires off each piece that you are conducting the test to or your test would be inaccurate if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to continue helping others in similar situations in the future I await any further reply
p.s if this is a whirlpool or kenmore dryer i would first check the run relay found behind the rear panel of the machine Thanks again Rick
Posted on May 31, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: all mechanical function work well
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Sep 03, 2011
machinetech7
Jason Kennidy
  • 1344 Answers
SOURCE: My kitchenaid dryer won't heat up.
First you have to determine whether you element is in the front or the back of the machine this is done easiest by looking at the front of the machine and seeingif its one complete piece or two. If its one, the element is in the back, if two its in the front. We'll start if its in the back first. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced. Now if the element is the front everything is the same with the exception of you have to remove the lower portion, usually held on by 3-4 screws located underneath.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Jun 05, 2012
GAS dryer will operate, but not heat. No error codes showing
If not heating at all try this. Go to electrical panel box and find the breaker labeled Dryer. It should have 2 joined together levers. Turn it off and see that the dryer is OFF (this verifies you have the right one) Operate this breaker back and forth (on and off) at least ten times. Then put it in the ON position and try dryer again. If it works you have a bad (intermittent) circuit breaker. Get an electrical handyman to change the breaker. If changing the breaker does not fix it you may need an appliance repair person. Why this is. The cycling on and off of the heat at the dryer is rough on circuit breakers. If this dryer has been in place for some years and replaced another dryer it is probable that the circuit breaker was not changed. BTW the dryer functions (except heat) operate from one side of that 2 sided breaker, while the HEAT operates from both sides at HIGH current.
Mar 23, 2014 | Frigidaire GLEQ642A Electric Dryer
Buzzing noise from my dyer
You may be experiencing some feedback through a buzzer from the timer. Below is a link that may be of some help.
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 23, 2017 | KitchenAid KEHS01P Electric Dryer
Dryer wont heat up
Is the circuit breaker a duel bullet type fuse (2) in the case for the 220 line? Try changing them and see what happens.
Apr 07, 2013 | Dryers
Dec 31, 2011 | KitchenAid Dryers
Kitchenaid gas dryer won't ignite and heat. Everything else seems to work fine -- drum rotates, timer works, just no heat. Model# KGYL517BWH1.
heatman101
Sep 10, 2011 | KitchenAid Dryers
All mechanical function work well except dryer will not heat up ,blowing cold air.Model DCLR333ETOWW GE
heatman101
Sep 01, 2011 | Kenmore 62822 Electric Dryer
Dryer works great except there is no heat to dry the clothes. Fuses have been checked.
heatman101
Mar 19, 2011 | KitchenAid KEYS750LQ Electric Dryer
I have a kitchenaid dryer that worked fine all day and then my last load to be dryed no heat not at all
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 23, 2010 | KitchenAid KGYS750LQ Gas Dryer
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
Mar 22, 2010 | KitchenAid Dryers
Dryers Logo
57 people viewed this question
Top KitchenAid Dryers Experts
Marvin
Marvin
Ekse
durantheman
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
