SOURCE: my samsung blackjack 2 will
If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
SOURCE: mp3 will not connect with my computer
I had the same problem. Don't buy a new cord. There is a sony place in winnipeg you can get it fixed there.
SOURCE: Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
SOURCE: Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
SOURCE: Cannot turn my i pod touch on
your ipod seems to be having problem like damaged system software. you can reinstall your ipod software but will erase anything on your ipod, don't worry you can sync them again. here's how to do it.
make sure itunes is open and connected to the internet.
Hold down your ipod power button, then hold down the home button too, this will force the ipod to restart and in restore mode.
the screen will go dark and restart, now release the POWER BUTTON while still holding down the HOME BUTTON.
It will show an itunes icon and a USB icon saying connect to itunes.
NOTE: you might have to do this procedure many times in order to show the itunes and usb icon.
Now release the HOME BUTTON and connect to itunes, it will erase your ipod and download software from apple to install on your ipod.
this might take some time, wait for it to complete the task and now you are ready to use your ipod again.
Please rate. Thank you
