I have a problem with my Hunter Newburgh Type 2 ceiling fan.
The fan runs at low speed 24/7. For months, I have not been able to adjust the fan speed with the remote and now, the remote won't turn the light on or off either. How can I determine if the problem is located at the fan which is 20 ft up from the floor or is in the remote?
I have a Hunter fan that is about 10 years old. The remote receiver stopped working. Unfortunately, Hunter has discontinued the part, 85112-04. This item works ...
Original Hunter Receiver 85112-04 (8511204000) is no longer available and is replaced by our FAN2R KIT. Works for: 3 Fan speeds Low, Medium, High, Fan ...
US$59.99 · ‎In stock
Find many great new & used options and get the best deals for Hunter Fan Receiver 85112-04 at the best online prices at eBay! Free shipping for many ...
Rating: 4.8 · ‎4 reviews
Delivery between Monday, May 24 and Tuesday, May 25. Order within 23 hrs and 28 min. This item is out of stock. We'll email you when it's available! Product ...
US$55.00 · ‎In stock
I have a Hunter 94974 fan receiver 85112-04. All remote functions work except it won't switch to the lowest fan speed. The red light goes on when I hit the button. Is ...
My Hunter fan uses a Zing-Ear ZE-268S6 switch. This is NOT a standard switch! It connects L to 2 AND 3 for medium speed. It is best to order the exact switch if possible. Hunter wants to sell you the entire bottom assembly (probably expensive).I found the exact switch online at:
for $6.80 plus $4.95 shipping. I bought an extra which didn't increase the shipping - worked great. Hunter ZE-268S6 ceiling fan connection colors: L=black; 3=green; 1=grey; 2=brown. If you need a different switch on their page, just click the Edit menu, then Find, type your part number in the box, and click Next.
well, they could have. but before you throw it out, go to the hardware store, and buy a new pull switch. either that, or just run it with the high and low speeds. It shouldn't hurt it at all. But, if there is any clicking sounds, or wierd noises coming from it , DON'T USE IT!! it may catch fire. but it did last a long time. 20 years is good for a modern celing fan. though I like my antique 1907 westinghouse 72 inch 2 blade fan. It hasn't died yet!!!
Sounds like the variable speed switch may be worn out. You should be able to purchase replacement switch at the local home depot- type store in the electrical supplies. Trying to get an exact match to replace may be a bit difficult, but a similar 3 speed switch should work just fine.
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
A fan that old has a muilti speed capacitor. It could be that or the swicth. First thing to do is test the swicth with a voltage tester to see if power is switched to different posts if it does switch it is prob. the cap. Good luck trying to find one.
