Dryers Logo
Carrie Thomas Posted on Sep 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Danby Dryer DCD5505W-1 has a "ka-thumk" noise with each rotation of the drum. The noise is coming from the lower part of the dryer. Roller support wheel problem? Belt?
David Emmel
Level 2:
Sergeant:
  • Expert 295 Answers
  • Posted on Oct 01, 2017
David Emmel
Expert
Level 2:
Sergeant:
Answers
295
Questions
Helped
128296
Points
781
The model did not return any information,so I am unable to supply you with any assistance there. The noise could be a roller, belt, foreign object in a loose baffle, idler pulley. Double check your model no. then reference the link provided,..... https://www.repairclinic.com/ for detailed info.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
5 Related Answers
Anonymous
  • 3422 Answers
  • Posted on Jul 03, 2008
SOURCE: replacing bryer belt
Please CLICK HERE this will fix your problem.All the instructions are given step by step with the diagrams.
Anonymous
  • Posted on Dec 22, 2008
SOURCE: dryer belt PH 1930 for danby model dcd5505w-1
Call Danby Customer Service at 1-800-263-2629; The part costs $25 or so plus another $7 shipping. Better than getting it through a distributor, I was given a price of $40 through a local place.
Anonymous
  • Posted on Jan 14, 2009
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Anonymous
  • 121 Answers
  • Posted on Jun 02, 2009
SOURCE: Danby Dryer too hot
First of all, check to see if you have a hose going outside that is fully clear of lint from beginning to end. then check to see if your heat is staying the same on a empty load run machine empty, then turn your thermostat to cool after it heats up and see if the temp went down to see if working properly.
Anonymous
  • 1776 Answers
  • Posted on Sep 30, 2009
SOURCE: running with no heat
Check for a blown thermal fuse or a faulty heating element. Both components should be located inside the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty component. Really sorry for your trouble and I hope this helped. Best wishes.
With regards to Danby Dryer, Model DCD5505W, is the belt positioned around the drum ribbed out or in?
The belt on the Danby Dryer Model DCD5505W should be positioned ribbed out.
2answers
Blowing heat, not spinning!!!!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
My danby dryer DCD 5505W is making a squeaky noise.
You need to change its Drum bearing and front rollers. Also replace its Drum glider/pads.
Searching for a Danby Dryer belt
appliance parts pros 1-877-477-7278
3helpful
2answers
Dryer runs but wont tumble
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
3helpful
Dryer belt PH 1930 for danby model dcd5505w-1
2answers
Door Handle Broken
yes contact your local appliance dealer or if you have the manuals that came with this dryer contact the manufactuer by the listing on thier literature.
Or do a web seach LIke :DANBY DCD5505W DRYER PARTS
Top Danby Dryers Experts
Jorgie  the...
Jorgie the...
Amy Smith
Amy Smith
Are you a Danby Dryer Expert? Answer questions, earn points and help others
