SOURCE: dishwash machine electrolux esf 6121
Easy fix, had same problem on our. behind the red lights there is the electrc stuff, when you open/close the machine the solderings crack. remove screws until you can get off the panel, then there is some small hooks that hold the board, loosen all contacts and take out the board, check the solderings around the relais and re-solder them, i resoldered all spots on our board.
SOURCE: Im not getting any heat
The heater element should be tested first. Use an ohm neter the reading should be around 30 ohms. If thats ok test the thremostat that is directly connected to the element. This should read zero ohms. if that testsok the check that there is the correct voltage to the heater. This procedure should only be performed by a licensed qualified person because you are dealing with live power. If there in no voltage to the heater test the wiring from the controller, then test whether the controller has power leaving it . Perhaps a technician should be called.
SOURCE: Dishwasher ELECTROLUX ESF 6121 WHEN STARTING
this fault can be the heater which has an electrical earth fault. You need an insulation tester to test it. The heater is accessed from the right hand side and is a cartridge type insert in the flow to the top spray water supply.
SOURCE: wont finish wash and drain
I would turn off main power then open the controls looking for any burn parts on the power board before calling any one , how ld is this unit before yu spen too much get back to me
