Question about Locks & Locksmithing
How do you release the screen from the Emco 300 series storm door? Can't get the screen to move down from its shipped retractable position. The orange tab won't move.
Posted by djbeas on
5 Related Answers
JUSTOLDJIM
James Cagle
  • 482 Answers
SOURCE: Carriage return problem
Try pressing the margin release key then backspace and reset the left margin.
Posted on Jan 23, 2008
dewan nafees ahmed
  • 1894 Answers
SOURCE: AVIC - Z1 Screen no longer retracts to allow insertion of a CD
that means that the CD drive is not opening right?
it may be a gear problem sir
Posted on Jul 30, 2008
Anonymous
SOURCE: accoustimass 15 speaker problem
more than likely your speaker terminals are broke. Those type of terminals have springs inside to push them down onto wires. more than likely the terminals will have to be replaced.
Posted on Aug 26, 2008
Dick O Reilly
  • 3594 Answers
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Posted on Dec 08, 2008
Joe Hogan
  • 10865 Answers
SOURCE: My fuel door release button is stuck down and I
lubricate the latch with a penetrating lubricant such as WD-40. Repeat as needed. J.
Posted on Sep 27, 2010
Cost to replace 2 storm doors
unable to give an actual cost due to prices and labor are different for product and area door can be around 100 to 150 each depending on size and accessories attached and labor is a complete variable as to any addition repair to entry replace remove molding frame repair -replace each can be 100 to 300 to do we cant see what work will need to be done --call or ask around in your area or place of purchase for some one to give an estimate to you
Aug 24, 2016 | EMCO Door. 300 Series 32 in. White...
How do i get the windows out?
Release Tabs At Bottom Remove Toward You--Then Bring Top Down In Track And Tilt In Track To Remove
Feb 18, 2015 | EMCO Door. 300 Series 32 in. White...
Sping in Emco storm door latch broke
I found a video that may help you listed below.
Best Regards my friend!
Mar 04, 2014 | EMCO Door. 300 Series 32 in. Bronze...
I have a Simplex Kaba Ilco Unican 1000 keyless lock and I want to change its password. But I don't know how to do it. Is there anybody to help me? It's urgent please...
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Good Luck!
Mar 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Hi, I have an older version of the Ilco unican corp pistol safe. IT is a simplex with the push buttons and a silver turner. I got it open, but don't know how to re program the code. Any help?
pctuneup191
REMOVE THE KEY.
Good Luck!
Feb 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Lost code for 5 number lock
REMOVE THE KEY.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Good Luck!
Jan 26, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Reset combination to keyless door lock
REMOVE THE KEY.
Dec 09, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Need instructions on changing combo
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O’CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O’CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O’CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
REMOVE THE KEY.
Aug 04, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Locks & Locksmithing Logo
213 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
