SOURCE: Mitsubishi 60 inch projection
They are not BULBS by any stretch of the imagination. They are CRTs (Cathode Ray Tubes, also known as "picture tubes," and each of them are small television screens, in essence), which are optically enlarged for projection onto the back of the front screen. Don't be tempted to think that you will merely be able to replace a "bulb" and have everything work!
Although you will be able to replace all of the components on the PC board if necessary (they all remain available), and may be able to fix the coolant leak that caused the failure, the CRT may have overheated. Considering the advanced age of the television, the tubes are likely already somewhat burned-in. Best to just dispose of the set.
SOURCE: Mitsubishi (2001 ?) 60 inch
My mitsubishi 2001 tv model 60609 plays sometimes for a couple of minutes and then turns off; but you can still hear the volume and if you try to turn it back on it will turn right back off.
please help me!
SOURCE: mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
SOURCE: Mitsubishi rear projection tv will not turn on.
Call Encompass Parts they will have Boards for this TV or just go to there website type in your Model number 1-800-638-3328 They will List Parts Board# and Price$
SOURCE: Mitsubishi VS 60609 60 inch
Hi, I need a Diagram for a Mitsubishi VS-60609 my E-mail: [email protected] Thanks!!!
