SOURCE: nec gt5000 projector turns off 10 seconds after power up
that is usally cause of the lamp this is not in my expertise but that happened to my dads one if the lamp is at the end it will shut down it usually give warnings first like change lamp then its over has to be replaced
SOURCE: NEC MultiSync VT540 not turning on - Temperature error
Hi
if the status light is blinking red in 4 sec interval it means that there is something wrong with cooling system. you shold check if there is a thermostat failure or if there are any switches that are not turned on. i suggest you to open the device (using screwdriver) and check if there are any switches broken or damaged.
i had pretty much the same problem (one second interval). i took off the cover and there was a broken switch and i just short-circuit it and now it works
Sorry for my english
SOURCE: NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
SOURCE: Flashing red status light on NEC VT45 projector
make sure the doors are shut all the way! there is a little button there.
SOURCE: Steady red status light on NEC VT45 projector.
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
