Go into the settings and go to memory card/SD card and format the card it will erase it.
Is it an android with a removable memory chip? In which case take it out and reformat it. You will need a card reader with a USB hook up for your computer. Or if it is an iphone go to the app store and find a file to download that is much larger than the memory capacity of the phone. The phone will erase everything non vital trying to down load the file. This is what the apple store does to wipe all the search history files off the phones.
SOURCE: virus on cell phone memory card
1. you can remove the memory card from your phone connect it to a card reader and format the memory card or scan for virus.
1. If you have a compatible cable to conect to PC then you can connect your phone is memory card mode (mass storage or data transfer mode) and then scan for virus. if the virus are detected from the anitvirus it's good else i would suggest you to format your memory card.
SOURCE: Virus in my Memory Card. It is not allowing to save the Photos
ur memoryt card is been corrupt try to install a new one
formatting the memory card automatically erases all the files in the memory card.
it's like restoring the memory card to factory settings to be compatible with your camera.
when you format the memory card using the camera the camera erases everything then creates folders that the camera needs to store pictures in your memory card.
you can try to look for software that can TRY to retrieve the images but i cannot assure you that this will work
SOURCE: My 512 MB Micro SD memory card is locked
Recently I wrote an article to recover deleted SMS from mobile phones . Here is another related one ,which deals with memory card password . We can use the same software that we used in the above case to recover memory card password from mobile phones .
Method 1 : Recover memory card password , using Fexplorer.
As I said, we need Fexplorer for this mobile hack .After installation , Browse to c:\system folder in your mobile phone . Here you would find a file mmcstore .This file is actually used to store memory card passwords in a mobile phone . Rename this file to mmcstore.txt and open with notepad . Now you will see the memory card password as it is ,exactly .
Method 2 :Unlock memory card passwords of Nokia Nseries and Eseries phones
The first hack to recover the password of memory cards will not work on Nokia Nseries and Nokia Eseries devices . Here we will use the remote lock feature for re-setting the password . For this , go to your pones settings >Security >Phone and SIM> and then allow Remote lock . The password of your remote lock will be the password of your memory card .So if you want to change the memory card password , just send an SMS containing your remote lock message .
u can also download from this site
http://www.mobiclue.com/2009/02/recover-memory-card-password-from.html
SOURCE: My phone can't read the memory card.it gives me
If the memory card worked before with your phone, then suddenly became unrecognized, then the memory card probably got corrupted.
The best thing that you may try is to insert the card to another phone and connect it to a different computer. There are times that another computer recognizes the card with this kind of problem.
If a different computer recognizes your card, immediately back-up the files, then reformat your memory card. However, if the same problem occur on different computer, then there's nothing that we could do but to reformat it.
Whether you reformat it or not, you could no longer recover the files if it's still unrecognized.
Thank you and good luck!
