Model un46b8000 seral az4k3ckcks701919d version sq01
SOURCE: Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
SOURCE: SAMSUNG TXS3082WHX/XAA Won't Turn On
All of these tv's are board replacement only the individual parts are not available. The boards can cost anywhere form $200 - $400 each. Even if you do it yourself it is still an expense, if you get the blink code i can point you to the correct board. These sets have different boards even within the same model range. One of the first diagnostics is does the back light come on, if not then you either have a balancer error or a bad bulb in the panel. Why i suggest this is because it is the most common problem. If it is the bulb in the panel you have to replace the whole panel, the bulbs are not available as an individual part.
SOURCE: 32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
SOURCE: looking for a comcast remote code for a samsung
0060 did not work for me but putting a 1in front of it did the trick!
Try 10060
