Question about Schiller Medical
How do you change schiller ekg from 6 lead to 12 lead?
Posted by stacy hill on
Ron Jones
    New Friend:
  • 17 Answers
6 lead / 12 lead EKG. It is unlikely that you can do that with your machine. 6 leads are rarely used and would require a totally different internal format. 12 lead Ekg is the standard of care. Chose 12 lead and dont worry about finding a 6 lead. RJ
Posted on Sep 28, 2017
5 Related Answers
Anonymous
SOURCE: Schiller AT-2 EKG
YOU CAN, CALL ME 909-599-1789
Posted on Jan 29, 2009
Anonymous
SOURCE: the window on our schiller AT 2 plus ekg machine is too dark
When you first turn on the machine, hit the up or down arrows to adjust the brightness of the LCD screen.
Posted on Mar 13, 2009
Anonymous
  • 10 Answers
SOURCE: need user manual for Welch Allyn EKG machine -
Call Welch Allyn, they will email you a manual for free
Posted on May 14, 2010
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: how do you set time and date on schiller at2 ekg
HI,
To set time on the schiller AT2 do the following.
1. Power ON the machine.
2. Press the following key sequence ALT,9,1,1.
3 Now enter the time using the digit key (HHMMSS)
You will hear the conformation beep indicating that the time is seted.
To set the date on schiller AT2 Do the following.
1. Press the following key sequence ALT ,9,2,2.
2. Enter the date using the digit key (DDMMYY)
You will hear a conformation beep indicating that the date is seted.
ok
Posted on Sep 11, 2011
SOURCE: how to replace battery in
The battery in the Schiller AT2 is as 12 volt 2.2 AH battery commonly available from R&d batteries, there part number is 5515. To replace it requires disasemble of the unit. Note that you should never disasemble this unit while it is plugged in. Also there are several cable that attach teh top housing to the PC board, and if you are not dillagent about not pulling these vcables apart while disasembling the unit, you can do expensive damage. Bearing that in mind, I would proceed as follows:Turn the unit upside down on top of a towed or other soft surcace to prevent scratching the soft plastic of the upper housing. around the perimeter of the case you will see several screws, i think 8 if i remember correctly. Repmove them and place them in a cup or other container. Grip the top and bottem cases together firmly and flip teh unit back upright. GENTLY lift up the top housing, and VERY CAREFULLY slide it about 3 or so inches to the left. This will expose the battery. just lift it out and replace it with the new one.Take care to reconnect the wires in the same position as teh original battery. Mis wiring the battery will cost you hundreds of dollars. The wires connect via slide on spade connectors. grip them by the connector itself(not the wire going into it) and gently rock it side to side while pulling, it will eventually come off the battery terminal. Resemble the unit in the reverse order. Plug the unit in and fully check it prior to re-installing the screws in the bottom of the unit in case you pulled a cable loose. As an alternative, you can detach the cables from the pc board and place the top cover to the side while replacing the battery, but be VERY careful with the cables. I recommend that you have a qualified individual preform this replacement for you. the cove being removed exposes high voltage, and also presents the risk of expensive damage to your unit.
Posted on Dec 05, 2011
1helpful
Schiller at-1 says lead off
Check the leads. If any of the Leads is open the this problem can occur. You have to check the continuity of each cable for the lead end to socket. All leads should show a resistance of 10KOhm
If you wish to get some details About schiller AT1; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
The machine prints Lead I but nothing else. What should I do?
Your print head probably needs adjust. The Schiller ekg machines are notorious for these issues. You may want to send the machine in. We/ Discount Cardiology will look at your machine for free and call you with a diagnosis. I am 99% sure that this is the issue.
I change the paper and now machine runs only in manual mode only. I want to run it in auto mode.
Be certain that you have the correct paper in your unit. THe Schiller AT2 uses a black Que mark on the paper to start the Automatic 12 lead. If the device fails to Que, it will never start an auto run, but manual(rhythm) functions will still remain. The part number paper you should be using is 2157-017A.
Do u have a picture on how to put leads on a pt for a Schiller AT-2
HI,
Watch the following picture and video to know about the 12 lead ECG placement.
OK
Do you have a poster for correct lead placement for AT-2 plus ECG? thanks!
hi,
If you need to know how to place the leads then whach the following video. All 12 channel ecg machines have the same lead placement
My AT-2 plus EKG suddenly stopped transmitting from the electrodes, i.e. all the leads show flat line. My e-mail is [email protected]
hi,
You have to check the patient cable of you machine first. you have to check the LF (left foot ) lead of the cable. if there is any other cable you can try it with that. if there is any other ecg machine you have which has the same connector. then try with that also. if the cable found faulty then replace it. Is there is any trace ( line trace ) in the paper for lead 1 to v 6 if not , the problem is with thermal printer of you machine. if so you have to contact the nearest schiller authorized service center. Because the thermal printer head is not available in the open market.
ok
2answers
Won't give print out on Automatic but will give on manual
Turn off the machine & then turn on after 10 seconds. than press ALT 1 1 0 STOP in a sequence. That will solve your problem for printing in AUTOMATIC Mode
I ahve a schiller welch allen EKG machine, and now it only prints
If it stops printing completely in the middle of doing the print, it is because the battery is bad and needs to be replaced.
If it only prints some of the leads but it does print the full report it is because you have the leads mixed up (Wrong spot on the patient) or the leads are mislabeled or some of the clips or electrodes are bad.
I can fix these. Let me know if you need help.
Printing 3 leads only not 12
Hello medico001, The info on the Schiller web site states an option of 12 lead for model Cardivot AT. If your unit has this option only the automatic selection will deliver the 12 lead print. For futher info select the web site http://www.schilleramerica.com and click on 'Contact Us'. This should direct you to someone local. Good luck.
2answers
Schiller AT-2 EKG
Hello Genesis3kr, You changed the mode by selecting automatic for the 12 lead function rather that the manual. I suggest an operational inservice from your local Biomed Technican or education dept. If nether is available than contact 'http://www.schilleramerica.com' select 'Contact" and request a local company rep for one and bill your education or Biomed dept. (been there do that). Good luck. Please inform me of the out come.
Medical Logo
Top Schiller Medical Experts
Mark Ultra
Tom Chichester
Are you a Schiller Medical Expert? Answer questions, earn points and help others
