Question about Dell Computers & Internet
Hi, I hv installed windows 7 in my Dell Inspiron Model N5030 laptop but there is no option available to connect WIFI. i hv also install VM in my system. plz solve
Posted by Ravi on
Minister Ruland
    Sergeant:
  • Dell Expert
  • 445 Answers
You will have to go on a different computer and go to dell.com and down load the drivers and then install them on the computer you installed windows 7 for I had that problem when I installed w7 and that is what I had to do. So from then on i downloaded the drivers and put them on a usb and keep them with the w7 install disk. so if I had to reinstall w7 again i had the drivers.
Posted on Apr 24, 2019
5 Related Answers
Donald B Stoll
  • 597 Answers
SOURCE: i hv installed windows 7 but my motherboard cant
Well it's hard to make out this whole problem. Your sentences run together and you use no puncuation. Your typing or spelling causes you to leave out a lot of critical vowels from your sentences. If you can't get a motherboard driver I guess you don't get to play with Windows 7 yet.
Posted on Jun 08, 2009
sparky1500
Matthew Spark
  • 1066 Answers
SOURCE: p5pe-vm drives r not supported for windows 7 ...
windows 7 uses vista drivers.
Posted on Oct 09, 2009
Anonymous
  • 218 Answers
SOURCE: Hv Printshop Version 21 I use in laptop with
new software if im right that software isint compatable with windows 7
Posted on Mar 12, 2010
Ralph Grassi
  • 62 Answers
SOURCE: i want wire less net
Use a wired connection, and download from Dell. Use the Service Code, found on the bottom for more precise driver choices.
Posted on Jan 22, 2011
brian soufane
  • 693 Answers
SOURCE: I recently formatted my system.
You need to redownload the drivers for you inspiron N5010 Go to this link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON_N5010&os=W764&osl=en&catid=&impid=
When you get there Then scroll down Then where you see "Operating System", select your operating system (ex: XP, Vista, or Windows 7). It will then show all the drivers for your operating system...scroll down until you see the network driver software and then download and reinstall the Dell Wireless 365 Bluetooth Module and download the Dell Wireless WLAN 1520 Half MiniCard Hopefully this will help...good luck.
Posted on Aug 17, 2011
My dell inspiron laptop model 9100 Windows xp Pentium 4
Dear I think that u have problem with display driver ... U need to update bios which is available on site then install display driver hope this will help u ... U hv posted less information in ur question
Dec 04, 2014 | Dell Computers & Internet
Network driver for dell inspiron n5030 is not installed
Drivers for Dell N5030 are available drim Dell Official Support & Downloads for Windows 7 32&64 Bit) and Vista 32 Bit.
Please visit the above link. Choose the Version/ Edition of the Operating System you have on you PC. Go to the Network Section and download/ install the required drivers. There are 4 Drivers available. If you know the type of network card you have on your PC, then its quite easy to select, otherwise download all the file and install them one by one.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 20, 2011 | Computers & Internet
I have a n5030 dell inspiron and i use to connect using wifi. The last time that i did use my laptop the wifi device is not working (the system says that there is no wifi & bluetooth devices). I use...
Make sure your wifi switch is turned on. If that doesn't work, try taking out the battery of your laptop, waiting at least 10 seconds, and then rebooting. If THAT doesn't work, try system restore and take it back until before your wifi quit working.
Aug 22, 2011 | Computers & Internet
Hi , i m using dell inspiron N5030, but my laptop was not supporting windows xp, then i install here windows xp+darkedition v7 from then i m tring to install wifi driver but since dell wont provide...
hey You just download patch , which will make your windows 7 driver compatible to windows xp and then before installing it go to wifi software property and then make it compatible to windows xp
Aug 21, 2011 | Computers & Internet
WiFi can't instlalling in my laptop(dell Inpiron N5010),
Driver for Windows 7 (32-bit and 64-Bit) are available.
As the laptop comes with 64-Bit version, these drivers are available at Dell Official Site.
Dell Inspiron WLAN (Wifi) Driver for Windows 7 32Bit are not available from Dell Official or Microsoft Update (online).
I came accross this issue and solved it by searching 32Bit Drivers for the WLAN hardware and found the drivers. Below is the link from Intel Official Support.
Intel WiFi Link 1000BGN Drivers
Download/ Install the drivers/ and Enjoy wireless internet connectivity!
From adaptor properties - Advanced, select AUTO for 802.11n Channel Width to experience 300Mbps downlink Data Rate.!!!
CreativeTECH
May 28, 2011 | Computers & Internet
Hi can you tell me where I can get XP drivers on a dell inspiron N5030
Here is a website I found containing drivers for the Dell inspiron N5030 for XP. While I haven't tried the drivers myself, it does list the specifications of the laptop, and lists each driver for each hardwar.
http://www.downloadatoz.com/driver/articles/dell-inspiron-n5030-drivers-download-for-windows-xp.html
Mar 28, 2011 | Computers & Internet
I can not find driver for xp of dell inspiron n5030
You can find all the drivers for the Inspiron 15 (N5030) at the Dell website here. Since Dell does not specifically include Windows XP drivers, you should first try the Vista drivers, since most of these will work with XP.
If you need a specific XP driver for a certain part, like the wireless card, you'll need to go to the manufacturer site.
Mar 03, 2011 | Dell Computers & Internet
Dell inspiron n5030 xp drivers
hello
i want drivers of dell inspire n5030 wireless drivers for the xp
Oct 20, 2010 | Dell Computers & Internet
Dell n5030 laptop driver for xp
Inspiron N5030 drivers
Choose an Operating System,
and than click find downloads .
Good luck.
Oct 09, 2010 | Computers & Internet
Open Questions:
Computers & Internet Logo
53 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
