Air Tools & Compressors Logo
l
larry Posted on Sep 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will a air compressor that runs at 11.8 cfm at 90 psi run at 10 cfm at 100 psi?
Bill Boyd
Level 3:
Top Expert:
  • Psi Master 53,816 Answers
  • Posted on Sep 25, 2017
Bill Boyd
Psi Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949874
Points
172802
If it is a 11cfm compressor then it produces 11.8 cfm of air regardless of the pressure
pressure has nothing to do with cfm but with the restriction to air flow
for example the tire inflator -air hawk- has a very small cfm but as the tire restrict the air flow the pressure builds up to set pressure on the gauge
so if you want 100psi from the 11.8cfm unit just adjust the pressure switch to shut off at 100psi
Cfm is only important when using air tools as a compressor that is not capable of maintaining the cfm thereby the pressure to run the tools is not a good idea
as an example
a sand blaster that uses 11.8 cfm at 100 psi will not work on your compressor
that unit will require a 20cfm compressor to run it peoperly
  • larry
    larry Sep 25, 2017
    Ok so for example. I need 8 to 10 cfm at 100 psi to run my graco spray rig. Would the 11.8 cfm 175 Max psi compressor be sufficient?
  • Bill Boyd Sep 26, 2017
    the 11.8 cmf at 100psi will run the spray rig
    you will not be spraying at 175psi as paint sprayers operate efficiently at around 65 psi or lower
    running a compressor at higher than 120psi reduces the service life considerably
    If you are pumping paint ( airless spray gun ) the pressure is up to 1500psi but it is not a compressor operation but a gear pump that is producing the flow to generated the pressure
5 Related Answers
River bottom
  • 174 Answers
  • Posted on Jun 22, 2009
SOURCE: Air compressor motor stalls under pressure
this sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
Anonymous
  • 59 Answers
  • Posted on Nov 08, 2009
SOURCE: I have a small central pneumatic air compressor it
Most of the time the air flow rating for the air tools you are trying to use are rated higher than your unit, Check the lable on the tools and compare to your compressor, otherwise you have have some type of restriction in the air line or within the tool itself. Hope this helps.
rwooley
Robert Wooley
  • 190 Answers
  • Posted on Jan 02, 2010
SOURCE: oil free rigid air compressor will not get above
THESE HAVE TWO COMMON PROBLEMS. FIRST IS THE SMALL LINE FROM THE COMPRESSOR TO THE CHECK VALVE ON THE TANK LEAKING. OFTEN IT IS DAMAGED WHEN THROWING THE THINK IN THE TRUCK. THE OTHER PROBLEM IS THE TEFLON SEALING RING ON THE PISTON. AFTER SO MUCH USE IT SIMPLY WEARS OUT AND MUST BE REPLACED. I THINK IT IS A PISTON/ROD/SEAL RING ASSEMBLY, ALL ONE PIECE.
Anonymous
  • 169 Answers
  • Posted on Feb 25, 2010
SOURCE: What horse power is required for producing 16.9
You are looking for about 5 H.P. to do that, but what is more important is the r.p.m. of the motor, the size of the pulley,,, and the size of the compressor pulley! most manufactures will spec the pump for certain horse power,,, they go hand in hand,,, for example you cannot take a pump designed for 5 H.P. and hook a 10 H.P. motor and a bigger pulley on it and spin the pump faster to make more air,,, it wont take that high of speed,,, I hope this helps.
A
Anonymous
  • Posted on Oct 22, 2010
SOURCE: Hello , i found an awesome deal on the internet
Too small,on CFM
If your spending less than $400 to 800,forget it
I had a Campbell Hausfeld for 30 years,with 20 gallon
I replaced it with an upright,30 gallon
I do not use an impact on wheel nuts,ever,and I use a torque wrench set at 80# going on.
That has worked for me,damage free for 35 years.
What kills the air,is the air chisel and worse,the cut off tool,which you will use the most.
Make sure what ever you get, uses oil,the oil less units last about 3 years.
Two stage is best,but I still have a single
Has to be wired for 220 volt,unless you like paying the electric bill
So hope you have circuit breaker and 1900 box branch circuit wiring experience
Forget the gas engine,unless your going on the road every week
You need about a steady 100# to really run any air tool--so that translates to about 10 CFM,little pricy
GASKETS FOR VALVE PLATE WHO IS MFG ?
contact Northern Tool,scroll down the page and you will see parts offered as well as a phone number
FREE SHIPPING NorthStar Air Compressor Pump 2 Stage 3 Cylinder 14 9 CFM 90...
3helpful
I have an old craftsman impact gun model number 875-188992. what size compressor do I need for taking off lug nuts/automotive work?
The two most important specs are CFM at 90 psi (that's how fast the compressor can compress more air when the tank starts to run low) and how big the tank is. Virtually any compressor that has a top pressure rating 20 psi higher than you need for your tool (which is usually about 90 psi) and that has a tank of a couple of gallons will work. But the smaller the tank, the shorter time you can operate the tool before the compressor has to kick in. And the lower the CFM at 90, the longer you will have to wait for the tank to come up to pressure again so you can operate the tool at full pressure. If this is for occasional use and you aren't in a hurry, you don't need much of a compressor at all. If you want to operate continuously, then you should get something with a CFM at 90 psi that is higher than your tool's CFM consumption. Keep in mind that impact wrenches don't operate continuously like paint sprayers do. Good luck. Vote if you found this helpful. Al K
Hello , i found an awesome deal on the internet for an air compressor , its a briggs and stratton 15 gallon and it produces 4.2 cfm at 90 psi and 5.1 at 40 psi and it may run up to 125 psi. This is enought...
Too small,on CFM
AIR VOLUME REQUIRED
You need to look at the tool cfm requirements because they are posted on the package or usually in the ads. Your compressor will run the sander, just how long at a time will depend upon your tool's cfm. Rick
Copmpressed air problem
i can work this out ,but i`m not sure i want to,what are you going to do with that volume of air at that pressure?
2helpful
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
1helpful
Nail Gun how to
One of the factors used to designate compressor power is motor horsepower. However, this isn't the best indicator. You really need to know the amount of air the compressor can deliver at a specific pressure. The rate at which a compressor can deliver a volume of air is noted in cubic feet per minute (cfm). Because atmospheric pressure plays a role in how fast air moves into the cylinder, cfm will vary with atmospheric pressure. It also varies with the temperature and humidity of the air. To set an even playing field, makers calculate standard cubic feet per minute (scfm) as cfm at sea level with 68 degrees F air at 36% relative humidity. Scfm ratings are given at a specific pressure–3.0 scfm at 90 psi, for example. If you reduce pressure, scfm goes up, and vice versa. You also may run across a rating called displacement cfm. This figure is the product of cylinder displacement and motor rpm. In comparison with scfm, it provides an index of compressor pump efficiency. The cfm and psi ratings are important because they indicate the tools that a particular compressor can drive. When choosing a compressor, make sure it can supply the amount of air and the pressure that your tools need.
Nail Gun how to
1helpful
Compressor Support
Home Use: Compressed-air power tools can dramatically decrease the amount of time spent on a project. Many homeowners will use smaller, portable units (either hand-carried or wheeled) that move easily from the garage to the house, yard or roof. Common air toolsAir Tools such as brad nailersAir Nailers, reversible drillsAir Drills, and impact wrenchesAir Impact Wrenches require about 0–5 CFM (Cubic feet per minute — units in which air flow is measured). It's important to know if the compressor you purchase will drive the air tool you'll need for your project. For example, smaller air nailersAir Nailers run on 2 to 5 CFM at 70 to 90 PSI, while larger shearsShears, sandersSanders and polishersPolishers require up to 10 or more CFM and 100 to 120 PSI. Business Use: Air compressors used for business/professional applications are often classified “industrial grade.” They're packed with features that let you take on more demanding jobs with more horsepower, more CFM, more PSI and more (longer) run times. Though some industrial-grade compressors are portable, many are stationary units with large-capacity, ASME certified air tanks (up to 120 gallons), greater HP, more CFM air volume and faster recovery time to run a wide variety of air tools for as long as you need them to do the job.
Top Psi Air Tools & Compressors Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Psi Air Tool and Compressor Expert? Answer questions, earn points and help others
