Question about Belling Ovens
Https://www.manualslib.com/brand/belling/
pls look here
Posted on Sep 25, 2017
Testimonial: "Thank you but I cannot see the information I require"
ok you need to remove the power ie turn power off remove power cable,pull cooker out remove screws on back panel then remove door,now inside oven their is 4 screws 2 top 2 bottom then this is removed you will see fan you need to go to back and remove wire from the back pull through and do same when you put new part in
I'm afraid you haven't understood my question - It is the not the fan that needs replaced but the shaft of the switches that controls the fan oven and grill tempretures that has sheared off so need to access behind the control panel
their is 2 screws under the back panel remove,hit top to the front it will move 1 inch lift with care,you will see 2 screws at top left and right when this is removed your at front panel,remove part and put back the together,you just need to remove back panel under this 2 more screws hit top forward,lift with care 2 more screws under top face panel will be easy to replace part
SOURCE: belling synergie. oven
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Posted on Aug 19, 2008
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
SOURCE: Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Thankyou.
Posted on Feb 02, 2010
SOURCE: oven not heating up [fan works]
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Thankyou.
Posted on Feb 11, 2010
SOURCE: My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Posted on Mar 29, 2010
Testimonial: "Thanks "
Oct 31, 2016 | Belling Ovens
on Jan 17, 2010 | Belling XOU252 Electric Single Oven
on Jan 17, 2010 | Belling XOU592 / XOU593 Electric Double...
Nov 17, 2010 | Ovens
Jan 03, 2010 | Belling XOU492 Electric Double Oven
Dec 13, 2009 | Belling Ovens
Nov 18, 2009 | Belling Ovens
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Feb 14, 2008 | Belling XOU592 / XOU593 Electric Double...
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Jan 19, 2019 | Belling Ovens
142 people viewed this question
I will add more
