Televison & Video Logo
Question about Hitachi Televison & Video
Hitachi LE49s508 has sound but no picture. If you use a bright flashlight you can see the channel
Posted by Larry Paradis on
3 Related Answers
Anonymous
  • 2992 Answers
SOURCE: sound with black picture,some reflection w/flashlight on screen
The problem is that your TV's backlight has gone out. Without this light, the display still works but you can't see anything. It may be that the backlight lamp has failed. But a more common cause is failure of parts called capacitors in the set's power supply.
I've never worked on a Polaroid, so I can't point you toward any specific parts numbers or values. You may be able to find more detailed information by searching for your specific model and "backlight repair". Capacitors are cylindrical parts that vary in size depending on their value. When bad, they often have tops that are bulging (should be flat) or have split open, and sometimes there may be discolored areas at their bottoms from leakage. Replacing bad ones with parts of the same capacitance value (marked on the part in mf or uf, as in 330uf) and a slightly higher voltage rating often fixes the problem. (Not always, because other things can go wrong.) Capacitors also have a polarity, so you need to make sure the new part goes in the right way.
A TV service shop could check the set if you can't find more information or don't want to try it yourself.
Posted on Apr 07, 2009
Anonymous
SOURCE: we have a Hitachi 42hds69
Here is what you need to do to fix this. Call Hitachi Global Storage Technologies & request for the firmware upgrade.
1-800-HITACHI (448-2244)
They will send it to you for free. You get a small SD card that plugs into the back of your TV just below the Cable Card Slot. I wouldn'd have known it was there unless the instructions in the mail packet told me so.
To determine if you need to upgrade go Into the Setup Menu. Then, Go to Software Upgrades & look at the software version. I had 0110.xxxx. the version I upgraded to was 0125.0000 & it fixed the audio problem on 7-1 & 11-1.
now all channels work great.
THANKS HITACHI!!!
Posted on Apr 12, 2009
robblana
Lana Peterson
SOURCE: hitachi tv no picture
i have a hitachi tv and i tried to move it and i have sound but no picture could you help me with this
Posted on Dec 08, 2013
1helpful
Hitachi LE49S508 not powering up;changed main board, solved power problem, but now video is solarized...
Generally this is a tcon issue however if the set worked ok before the main board failed I'd have to think you have a bad replacement main, make sure the LVDS contacts are clean
Hatachi tv model #le49s508 manual
The Hitachi LE49S508 red LED lights up when the TV is in standby mode. The LED will be off when the TV is on or has no power. If you haven't tried the front panel buttons, check if the TV will turn on when you press the lowest button (Power) on right side of the TV. If this works and your remote doesn't, you may have a problem with the remote or the IR receiver. (You can check the remote by having someone take a picture of the front of the remote when you press a button. There should be a flare of light visible in the picture.) If your current source is a PC, make sure that the computer is on and hasn't gone to sleep. Otherwise, the TV main board is not getting power from the power supply or not responding correctly to the commands.
Sears Parts Direct has the owner's manual for the LE49S508 here: https://www.searspartsdirect.com/partsdirect/user-manuals/le49s508-hitachi-parts-manual . To download the manual, the current link is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1412002L.pdf . A few parts for this TV are available here: https://encompass.com/model/HITLE49S508 .
I hope this helps.
2helpful
When I turned on my vizio vo37om this morning, there was no picyture, screen is black. Sound is fine
Dim the lights in the room, turn on the set. Shine a bright flashlight on the screen, do you see a faint picture?
2answers
Hitachi tv no picture
It sounds like the tuner demodulator has failed. Many times I have found that it is cheaper to buy an external hi-def tuner than repair the one that is in the set. The fact that the tuner is finding channels but not displaying them is a good sign that the demodulator has failed. In one case I had with Sony rear projector, it would have been $800 to repair the internal hi-def tuner and the customer can buy an external tuner for $100-$200. Sorry if this is not the answer you wanted; if you fel this si a good response to your question, please be sure to rate me,. Thanks!
Green Screen
Sounds like the green tube is shorted.
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
