Question about Konica Minolta Office Equipment & Supplies
Konica Minolta C252 network ip address refuses to save........
Posted by Michael Ubek on
NAJI AZAR
    Habit-Forming:
    Scholar:
  • Konica Minolta Expert
  • 94 Answers
Check the network setting and we will go from there,
utility(Hard key)- 3)Administrator settings- (passwords is : 12345678) 5)network settings 1)TCP/IP settings
You might need to reset the login and password to be able to print to that printer, especially if the previous SysAdmin had set up the BizHub to require a login and password to print.
Posted on Feb 16, 2018
5 Related Answers
Anonymous
  • 145 Answers
SOURCE: KONICA MINOLTA
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Posted on Nov 04, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: konika minolta
CDC##  Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
Posted on Nov 07, 2008
Geekinator
Craig The Geekinator
  • 183 Answers
SOURCE: error code c-5102 in Konica minolta c252
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Dec 16, 2008
Anonymous
  • 167 Answers
SOURCE: I need the default ip address for the Konica Minolta C350
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
Posted on Feb 17, 2009
Anonymous
  • 3 Answers
SOURCE: Konica Minolta copier model C252 code C6102 any idea
C6102: Drive Home Sensor malfunction
1.Correct or change the Scanner drive
(cable, pulley, gear, belt) if it is faulty.
2.Correct the Scanner Motor set screw if
loose.
3.Adjust [Image Position Leading Edge] and
[Feed Direction Adjustment].
4.Check the PC201, M201, PWB-IC and
PWB-C connector for proper connection
and correct as necessary.
if all that doesnt work Change PWB-IC.
Posted on Mar 19, 2009
How to install konika minolta with computer
To get to the network settings: Press the Utility/Counter key, select Administrator Settings, enter 12345678 as the password, then select network settings. You will find all the settings for networking the machine there. The print drivers can be downloaded from Konica's web site: kmbs.konicaminolta.us
User manuals can be found there as well.
Feb 18, 2015 | Konica Minolta BizHub C252
How can I download driver for Konica Minolta bizhub C-252 on windows XP and direct to unit with ethernet cable?
Robert, C-252 Copier prefers that you give it a IP address (Call Static IP) Do not use DHCP which the network determines .
Go Administrator, Admin One Network TCP/IP have your network administrator determine best IP address for your network.to give the copier
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 17, 2014 | Konica Minolta bizhub Office Equipment &...
Restore network setting
then you will have to set up the ip address and subnet
Apr 25, 2014 | Konica Minolta BizHub C252
Konica Minolta bizhub C252, network settings not available
go to google then in the URL box not search type in the ip address of the copier will get the copiers web page. log in as administrator theres a tab for network then select scan to email smtp info goes there
Jan 27, 2018 | Konica Minolta bizhub C250 All-In-One...
Can not make bizhub c252 scanning trough e-mail feature
Can you print to your PC? if yes you know how to assign ip address to the copier. I suggest is to go web browser and type the ip adress of the copier. log in to adminstrator the password 12345678 click network scan you have choices which scanning you want. SMB, ftp scan to email. If choose SMB first you have create Folder to your desktop and name it SMB all upper case and right click sharing and permit everyone . Then back to copier web browser click tab scan and type all the names you want. Scan to e-mail you have to click network and enable the scan to email enter the SMTP leave the port 25 do not change assign a valid email address to copier and enter email address of the administrator user id and the last is the pasword. Note: everytime you visit this page you should enter the password. then click the scn tab and enter all your email address. enjoyprograming!!!
Jun 01, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica minolta c252 how to sharing pc....
If you are just adding your PC to the network first go to control panel click network set-up wizard.
to add your PC to print add printer from the control panel and look for the network printer. last you want to scan go the internet web browser input the ip address of the scanner or copier click public or administrator enter password 12345678 and click scan tab and add your PC host name or your email address if scan to email.
HH
Jan 10, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub c252 network problem
firqst: DHCP disabled
copier IP adress should be 192.168.x.y
IP Pc must be 192.168.x .z (169.254.xx.xxx is a bad address!! = No-IP address !!)
see my recommendation for the scan on a previous post (http://www.fixya.com/support/t1395654-konica_c252_scanning_address_book_job)
Oct 09, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 250 scan to email error
Try re-entering user name and password or try a different user name and password for email account saved in the machine.
Jan 25, 2008 | Konica Minolta bizhub C250 All-In-One...
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Sep 20, 2007 | Konica Minolta bizhub C250 All-In-One...
151 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
