I have already tried removing the key and putting it back in, but it still gets stuck. Actual space mechanism is fine, but for some reason as soon as the key is put back in place, it gets stuck again. PLEASE HELP
SOURCE: fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
SOURCE: smith corona typewriter settings
I am not sure but I think you the code key while pressing the format key then make the selection in the display.
SOURCE: 2002 oldmobile bravada ignition key is stuck in lock position
try and turn your steering wheel a little bit left or right and and the same time try and turn the key when it turns toward the dash then try and turn the key back. try and repeat this several times if neccessary. this should work. please rate this solution. thanks
SOURCE: 1997 pontiac sunfire key wont turn in ignition
You will have to have the ignition cylinder replaced in the car. The only thing that keeps that ignition from turning is a little tang on the sdie of it. The only way that tang moves is by the tumblers inside the cylinder moving it. They will have a hard time replacing it too as they can't remove the cylinder from the bore until it is in the "run" position. Obviously there are ways to get them out but it usually involves using half the tools of a good tech's toolbox. if it is towed the towtruck driver will have to use dolly wheels or remove the shifter cable at the transmission to get it to move as it will be stuck in park- unless is a standard shift.
I am sorry for the bad news. Get a second opinion from somebody that can put their hands on it , but it sounds like you have a tried all or most of the tricks.
Good luck...........Scott
